0-60 8.4 seconds
    0-60 8.4 seconds
    So I was out screwing around with my blue 90 ACCORD for fun 216k miles automatic transmission absolutely no mods or upgrades all stock. Tires at 40 PSI upon take off I reached 60 MPH in 8.4 seconds on my stock F22A1 isn't that a bit crazy? I thought stock 0-60 was like around 10 seconds....My ignition system and everything is all newer and up to par but still DAM.. Just think of what it would do with some upgrades and a SRI. BTW I had a friend time me on his watch with a timer LOL.... If my 90 can do this I wonder what the 93 SE does with a F22A6? Actually that was a lie on the no mods I have EGR blocked off and a colder heat range spark plug installed witch shouldn't affect power all that much. So what do you think is this about right for this car? Seems a bit faster then it actually should be lol.
    That's not too bad times, but don't you dare think about adding a fart can muffler and doing ricer fly by's to ppl in town. Its just bad karma. lol. I do that sometimes in mine but I got a nice exhaust system so its not bad karma, haha. Plus I got like a 7 second 0-60, haha.
    Search the forums if you want to learn how to get more power with your setup. A few bolts on's won't net you any gains and might actually slow you down.
    I would look into an engine swap or rebuild with bigger, higher compression pistons. You could at the moment just swap an A6 cam, H23 intake manifold, add a header and exhaust (good kind of exhaust), and get a Pt6 ecu. That would gain maybe 10 hp if you did it right. I wouldn't touch the stock air box, that actually performs better than a SRI or a CAI.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
