I'm changing the Headgasket on a h23 right now and I can't get the head bolt off. Anyone have a tip or two to help me out? I'm using the 14mm socket, and extended the racket 10" longer so I can get more power with more leveage. But I still can't lossen the 1st head-bolt. How much power do you need to used? Should I give it all I got?
Removing head bolt
Originally posted by i_love_cb7I'm changing the Headgasket on a h23 right now and I can't get the head bolt off. Anyone have a tip or two to help me out? I'm using the 14mm socket, and extended the racket 10" longer so I can get more power with more leveage. But I still can't lossen the 1st head-bolt. How much power do you need to used? Should I give it all I got?
make sure youre using a 6 point socket, not a 12 point.
