Both sides for the CB7 are available from Honda again. For the last couple years only one side was available. I'm seeing both again now, albeit with a slightly higher price ($292 on Hondapartsnow.com).
Need to swap a driveshaft? FYI
My '91 LX build. Bought September 2017. Sold June 2020.
http://www.cb7tuner.com/vbb/showthre...r /> t=209871
Current mileage: 422679 11/21/19Tags: None
Is that remanufactured, or new? Pretty pricey. Majestic doesn't show them as available. Note: Left and right are the same axle for 5 speed cars.Last edited by Fleetw00d; 12-12-2019, 01:29 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
I'd assume they're new. Every part I've ever gotten from them was new, and there's nothing to indicate they're reman'ed.
Originally posted by fleetw00d View PostNote: Left and right are the same axle for 5 speed cars.
Last edited by wtfisafleek; 12-12-2019, 05:13 PM.My '91 LX build. Bought September 2017. Sold June 2020.
Manual cars use the half shaft across the back of the engine block, the left axle plugs into that. On automatics, there is no half shaft; the axle goes all the way from the transmission housing to the knuckle. When you go to select parts on the site, you would have to select an automatic model to see the automatic (left) axles.
In the past I have seen things like remanufactured brake calipers and steering racks on Honda part sites - they were identified as such.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Ah yes I see now. I switched back to viewing the AT parts and there's a more expensive shaft that pops up now, $354. Looks like the only difference between the different part numbers for identical sides is the origin of manufacture.
As far as differences in the MT driveshafts, if I remember correctly the splined ends differ as well. One side was splined the full length of the outer section, the other was splined maybe half of its length. I can confirm later.Last edited by wtfisafleek; 12-12-2019, 06:25 PM.My '91 LX build. Bought September 2017. Sold June 2020.
Originally posted by wtfisafleek View PostAh yes I see now. I switched back to viewing the AT parts and there's a more expensive shaft that pops up now, $354. Looks like the only difference between the different part numbers for identical sides is the origin of manufacture.
Originally posted by steelbluesleepR View Postthe outer joints aren't different, just the overall length and inboard joints.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostAt least for a 1992 LX 5 speed sedan, Majestic's site shows the same part number for both sides.
I'll definitely be calling them before I order anything.My '91 LX build. Bought September 2017. Sold June 2020.
