Started the car to go to work one VERY cold morning. Not even a click was heard. Nothing at all.
Jumped the car properly with another vehicle. Barely got it to start after 20 minutes of charging. Drove around for 15 minutes, came back, turned the car off, and tried to turn it back on. Nothing. Not even a click.
Went to have the battery tested at Autozone. They said it looked fine.
When we went outside to push the car around so that it would face outward so that I could do work on it, we had to have the key in the Ignition (II) position to bypass the steering wheel lock. We began pushing the vehicle in neutral. After about 1 minute, the accessory circuit came to life. Radio, cluster, clock.
What would cause this delay in power supply? My thought is a bad ground. I haven't checked anything but the battery capability yet.
I have looked at other posts, online CB7tuner.com Sticky'd resources, and wiring diagrams, but won't have a Multimeter until tomorrow after work. I just thought I'd put this out there now to see if everyone else is thinking like me that it sounds like a bad ground. When my car is out of commission like this, I don't do anything but think about it.
