ok so i want DRLs really bad ive been tryin to figure out how to make my high beams runs at half the intesity but i came up with nothing. I know it has to do with voltage, so does anyone know how to turn regular high beams into DRLs?
DRLs
You can't run regular highs with low voltage, you need to get the DRL's of the Canadian CB's...or you can get it from any other honda, but you might require some modding tho. (its like a little voltage box).
Or you can just disconnect the low beams and keep turn you high beems on.
______________________________
"I ran open header once, it was sooooo loud little kids were running for cover as I was cruising at 2000rpms. That was enough to know I shouldn't floor it."
DRL Fun
Originally posted by P3dr0 View Postok so i want DRLs really bad ive been tryin to figure out how to make my high beams runs at half the intesity but i came up with nothing. I know it has to do with voltage, so does anyone know how to turn regular high beams into DRLs?
Originally posted by pedroalcala View PostYou can't run regular highs with low voltage, you need to get the DRL's of the Canadian CB's...or you can get it from any other honda, but you might require some modding tho. (its like a little voltage box). Or you can just disconnect the low beams and keep turn you high beems on.
Originally posted by busak87 View Postfrom what Ive heard, you cant just get the DRL relay from a Canadian cb, you would need the entire Canadian interior harness and run the wire from the fuse box in addition to the relay...
Originally posted by mastajay723 View PostI have a 93 CB7 from Canada. the DRL light is on so the lights will only come on when i manually turn them on. i want to do the same thing with my HIDs once i get them installed. anybody know how to fix the DRL light problem?? i know the reg cb7s dont have the drl relay
* for some reason, I loose threads on this site easily. You guys stay busy.Last edited by James Matteu; 04-19-2010, 11:22 AM.1997 Honda Accord EX-V6:
C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
MPZA - Electronically controlled 4-speed automatic, 1 reverse
~170 cu. in. / ~170 ft. lbs. / ~170 whp
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
^^^^^^Sorry - no matches. Please try some different terms. ^^^^^^^
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
no update?1997 Honda Accord EX-V6:
Dammit. I searched Thread titles; "DRL" and got a bunch. timmy0tool even did a write-up using Insight modules.
just a note.. my '90 EX has full-intensity lows as DRLs. the light switch literally does nothing. the lows are always on regardless of switch position unless the engine is started with the parking brake up.
