camber problem??
    camber problem??
    i have a camber kit on the front right of my car but the only tire that has camber wear is the right front tire! wtf? if anything it should b any of the other tires that have the camber wear since none of them have a camber kit...
    anyone has any idea why this happens?
    1992 Honda Accord Lx
    [/I][/I][/I]
    You have to get alignment done after installing a camber kit.
    MRT
      well since OP did not explain installing a camber kit.
      seems you only have 1 side issues. so head on out to get an alignment and you should be fine.
      unless you lowered your car. What is your suspension setup?
      MadLab Racing
      Southern Maryland
        lol well yea its lowered,i wouldnt need a camber kit if it wasnt. i have gr2 shocks with skunk2 springs
        [/I][/I][/I]
          i think an alignment should fix the problem
          if not then maybe u should just remove the camber kit
          90 accord lx
          form > function
          Member's Ride Thread
            if you take it to get an alignment the place should adjust the kit to fix your problem, your toe may be off too, and possiblt your caster
