Old 10-02-2017, 06:26 PM   #1
zedjr10
Gold Member
zedjr10 may have said something they shouldn't have...
Best way to get broken sensor out from block.
I broke off the ect switch below the distributor. It is sealed and i used some stuff to glue the plug back on top. What is best way to get that lower part out. Is there some tool that extends teeth outwards to grip the walls then screw it out? I know i can't leave it this way forever and i want to replace that switch at some point but i wanted some advice on best way to remove this first.
zedjr10 is offline   Reply With Quote
Old 10-07-2017, 12:07 AM   #2
rustyaccord
CB7tuner Member
rustyaccord is cool... so far.
I would try a left handed drill bit. Though that sensor is probably stuck in there pretty good so they might not work.
__________________
rustyaccord is offline   Reply With Quote
Old 10-11-2017, 03:08 AM   #3
zedjr10
Gold Member
Quote:
I got a screw extractor, which is basically a left hand tapered drill. I think it will come out ok. Will do it when i get my oem sensor.
Old 10-12-2017, 02:32 PM   #4
G. Wiffington
CB7tuner Member
G. Wiffington is cool... so far.
How bad is it broken? I thought most of the sensors were removable because there is a way to put a socket around it to loosen/tightened?
G. Wiffington is offline   Reply With Quote
