I am in the process of my first build and trying to figure out if I have type s cams, I have 2 sets of cams and would like to figure out how to determine the difference between stock and type s ? They have somewhat of a blue tint to them.
difference between type s and stock h22 cams
Originally posted by Straight Success View PostMost likely duration and lift. I'll look into it as I am possibly interested in using these cams.
Can you just throw them on there and see a difference in power ?10th Anniversary Accord.
05 Audi A4 Ultra Sport 6MT.
You can but it's not really advised. You really should tune accordingly. The factory valve springs can work but it's similar to the situation people encounter when they put a 4A camshaft (F22A6 in the US) into an F22A1/4. It works but unless you swap in the appropriate springs you won't be using the ones intended for the lift of the upgraded camshaft.
And the blueish tint is not a giveaway. This is what pissed me off about the H23A VTEC thread on Honda-Tech. All of the H-series camshafts after a certain year were blueish. My '97 F20B has blue cams but it was an automatic and has, arguably, the crappiest cams made for an H-series. And I don't know about all H22A4s but the ones with the P5M heads seem to all have blue cams as well. None of these are Type S cams. You'll need to actually measure the cam to know for sure.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Yes.
Some people have reported increased wear on the rockers pads or the camshaft lobes but I have yet to see that substantiated by anything. The thinking is that the valve angle of the PDE head that those cams are usually found in works in synchronus with the profile of that camshaft and that installing them in a P13/P5M head changes this geometry and creates issues. I'd stipulate to this if only the manual transmission F20B with the PCB head didn't have them also. That's essentially a P13 head with smaller diameter combustion chambers. I think it's bull, but I just wanted to put it out there.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Just keep in mind that the 20 crank horsepower the Type S has over the base JDM H22A (30 over the USDM H22A1) is due to far more than just the cams. Intake manifold, cams, springs, mildly polished head (reported... I've never compared firsthand), possibly the exhaust manifold (I honestly don't remember), pistons, and the proper ECU tune. That's a LOT of parts for only 20hp... so it's reasonable to assume the cams alone won't give more than 5-7hp (crank) at best.
^ Right but if combined with power adders like the ones you said it could eventually add up.
Would that also increase MPGs or no ?
I'm just doing a lot of reading and searching becuase i want an H22 to be reliable but i want it to be able to spin the wheels sometimes10th Anniversary Accord.
For future reference for anyone wondering....I measured my H22A cams and Type S cams with my digital calipers on the VTEC lobe.
Intake:
H22A: 1.452"
Type S: 1.466"
Exhaust:
H22A: 1.432"
Type S: 1.446"
member's ride thread
91 Accord SE 176k
Originally posted by cyanide View PostVery good info! Can you measure the base circle? That would allow calculation of the actual lift and the true difference between both.
Also, what is the rocker-arm ratio of these heads? That would allow you to calculate gross valve lift.
91 Accord SE 176k
Originally posted by Straight Success View PostAny differences to report?
Used to die out around 90, now pulls pretty good to 110-120 (done on open road early in the morning) but can't really go past that b/c of my F22 5th gear limiting me.
Has a lot better midrange too. I noticed while driving in traffic, I don't have to down shift to accelerate from 30-50 when in 4th.
VTEC cracks a lot harder also. I feel more kick at 5200rpm.
some of this could be due to me adjusting the valves after 60k miles though lol.
But I'd say it gives a noticeable increase in mid-top end performance.
Definitely worth the 100 bucks I paid for them.
91 Accord SE 176k
