Best ecu for f22a4?
    $60? Shit... I was recently selling one for $50 shipped! Some friend...
    That package would work. More advanced than the basic setup I described above, but definitely capable. Neptune is powerful and well-supported. The Demon, if I recall correctly (I didn't read closely) is also a real-time device, so you don't have to constantly burn chips. I'm not 100% on how it works, but that's a good setup for sure.
      my car also wont rev past 5.5k but i don't believe it has anything to do with my ecu... if that is still your main concern, i'd work on figuring out the problem before tuning.
      MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
        Not revving beyond 5k should be an ECU issue.
          Awesomeee. But yeah I kinda just threw the $60 asking price out there and he jumped for it. But idk why it won't go past 5500. All sensors are fixed, I'm not getting any cel codes. My battery light is on though, I'm not sure why. But I'm definitely getting the tuning setup now.
            Limp mode perhaps? I am also with Deev on this one as well, I would try a different ECU and see what happens.
            The CB7 Collector.
            92 LX Coupe F22A1
            2013 Toyota Corolla S
            92 EX Sedan F22A1
              Would it be in limp mode although I'm not throwing any cel codes? I've unplugged the ecu and even did the well know disconnect the battery for 2 hour to fix the problem. Could I put the p06 ecu in it to see if it changes any? It's bone stock.
                Hopefully to make things a little more clear : http://m.youtube.com/watch?feature=c...&v=87DKOpRcWD4 this is a link to a video of how my car cuts back at 5,500 rpm's. Also, a horrible 3rd gear pull.
                  How is your timing?
                    Originally posted by dj_ender View Post
                    How is your timing?
                    Actually, I haven't checked the timing. How would I do that?
                      You'll need a timing light to check ignition timing. Valve timing can be checked by inspecting the timing marks on the cam gears and crank pulley (as long as your valves are adjusted properly.)
                      The battery light could be an indication of a failing alternator, or damaged or corroded wiring.
                      ALWAYS be sure to eliminate any known issues before upgrading. You'll only compound the frustration if you do additional modifications before you're absolutely sure your car is running properly beforehand.
                        I've replaced the alternator and belt quite a few times but came to find out it was the cables to the battery that caused the light to come on. I have a set that I can replace the old corroded ones with its just trying to find the time to be able to do it.
