Electrical Mishaps, Need advice....
    So I got my 90 LX and I noticed something today. When I'm in park and I turn on my A/C the radio start sounding like its grounding out and flickers, my tach will start jumping like a spastic retard along with my speedo and then the car sorta sputters then dies completely, any Ideas why? It does it also when I'm in Drive.
    It only does it when I turn the A/C on, not when I run just the fan??? Only the A/C...
    Any sorta guidance would be appreciated.
    My Project, My Concept
    1990 LX Coupe
    "Certified CB7 Tuner"
    What happens when you are driving and turn on the A/C?
    Does this only happen at idle?
    YouTube Clicky!!
      Sounds like it's grounding out like you said. Start checking all of your grounds and see if they are intact. I'd start with the thermostat ground.
        Come to find out it was my alternator, I had burnt it up, I replaced it and got a new battery and all works perfect now. Thanks for the advice.
        1990 LX Coupe
