having trouble to make the rpm throw redline
    i have a h23 throttle and i dont know if i need to tune the ecu can anybody help me
    What?
      Trying to decipher your english I come up with 2 things you are trying to say. 1) You're car isnt revving to redline. If that is the case then how high does it go, how does it behave? Could be dozens if not hundreds of reasons why it wouldt reach its redline but you need to tell us more. 2) You want the car to go past its redline. If thats the case then yes at a minimum a complete new tuned ECU. But the redline is there for a reason. After it you risk serious engine damage because your engine and its part are not designed to operate at those speeds. So if you want to go past redline more then once..you need to do some serous engine work first.
        There is also nothing to gain by going over the redline without mods to require it.
          Also, you do not need an ECU tune for an H23 throttle body.
            The h23 throttle body doesn't fit the accord intake manifold.
            http://www.cb7tuner.com/vbb/showthread.php?t=29727
              I assume he used the H23 plenum as well... it would be nice if the OP would clarify what he's talking about... and maybe say it in a manner that people can understand!
