Go Back   CB7Tuner Forums > Classifieds > Ebay-ONLY Classifieds
Old 06-23-2019, 11:12 PM   #1
af_1132
CB7tuner Member
af_1132 is cool... so far.
Send a message via Skype™ to af_1132
JDM Engine Goodies and other things for Sale!
Hey y'all!
Here is the link to my ebay selling page. There you will find the following items:
1. JDM H22/23 OBD2 TB 60mm SOLD!
2. JDM PDE-spec H22/23 plenum SOLD!
3. JDM H23A VTEC engine wire harness SOLD!
4. JDM F23A injectors
5. JDM H22/23A injectors SOLD!
6. JDM H22/23 fuel rail (plus banjo bolt) SOLD!
7. JDM H22/23 fuel pressure regulator SOLD!
8. Gates H22/23 auto timing belt tensioner (only 'cause its brand new)
9. JDM Tec TD-94U distributor SOLD!
10. JDM PCB-spec H22/23 IACV (3 wire) SOLD!
11. Gates H22/23 balance shaft belt (only 'cause its brand new) SOLD!
12. JDM H22/23 stock exhaust manifold and black painted exhaust cover SOLD!
13. JDM OBD2 EGR Valve
14. PCB stamped H23A timing side engine mount bracket
15. PCB stamped H22/H23A upper timing cover
16. 23T caliper brackets (new) SOLD!
17. Brand new unopened Honda OEM flywheel bolt SOLD!
All items are FREE shipping!
__________________
*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:55.317
af_1132 is offline   Reply With Quote
Old 06-24-2019, 07:23 PM   #2
Raf99
Gold Member
Is it the 23T bracket that works with the 11.1" rotors or is that the 25T?
Old 06-24-2019, 10:12 PM   #3
af_1132
CB7tuner Member
They will work with all the Honda/Acura 23mm rotors. Some 11.1" rotors are 23mm and some are 25mm. I am still trying to figure out all applications that are workable for these 23Ts and 11.1" rotors. Here is what I have so far:
Acura Vigor '92 - '94
Acura 2.5TL '96 - '98
Acura Legend '91 - '95 (Type I)
Prelude VTEC '93 - '01
Accord V6 '98 - '02
I'm not sure the ITR had 11.1" rotors, but they also use the 23T brackets.
If you have done your brake upgrade with any of those rotors, you will clear them properly with the 23T.
I found out the hard way at Laguna Seca how badly the auto parts stores can screw up on the brackets themselves. I went through a left front pad 100%, and decided to get new pads and calipers for the 25mm drilled wagon/v6 rotors I got from TAS before they went bust. Well, I got 23T brackets in the boxes, they don't work, and here they are for sale!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-06-2019, 08:11 PM   #4
af_1132
CB7tuner Member
UPDATE:
Just slashed prices by 10% to 30% on everything except the new Honda Flywheel bolt!
Check it out!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-11-2019, 02:10 AM   #5
af_1132
CB7tuner Member
Wiring Harness SOLD!
Slashed big ticket items again!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-13-2019, 02:08 AM   #6
af_1132
CB7tuner Member
Balance Shaft Belt SOLD!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-20-2019, 01:12 PM   #7
af_1132
CB7tuner Member
Just switched everything over to FREE shipping!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-24-2019, 10:42 PM   #8
af_1132
CB7tuner Member
Woohoo, just sold the exhaust manifold cover! Lowered prices again!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 07-26-2019, 12:10 AM   #9
af_1132
CB7tuner Member
Stoked! Just sold the distributor!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 08-06-2019, 03:26 AM   #10
af_1132
CB7tuner Member
The PCB Plenum and 23T caliper brackets sold!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 08-06-2019, 09:39 AM   #11
G. Wiffington
CB7tuner Member
G. Wiffington seems to have made some friends! G. Wiffington seems to have made some friends!
Got another H22 Distributor?
__________________
Keep Pushing..
G. Wiffington is offline   Reply With Quote
Old 08-07-2019, 11:13 AM   #12
af_1132
CB7tuner Member
Quote:
No sir, I wish I did. That item fetches a good amount.
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 08-21-2019, 12:23 AM   #13
af_1132
CB7tuner Member
Just sold the 3-wire PCB spec IACV!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 09-07-2019, 01:01 AM   #14
af_1132
CB7tuner Member
Sold the JDM fuel pressure regulator!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 10-05-2019, 11:46 PM   #15
af_1132
CB7tuner Member
Just sold the H23A Injectors!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 10-20-2019, 02:04 AM   #16
af_1132
CB7tuner Member
Woohoo, finally sold that TPS-less 60mm TB!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 10-31-2019, 11:27 PM   #17
af_1132
CB7tuner Member
Yes! Just sold the fuel rail to G. Wiffington! I threw in JDM studs as well, bud!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 11-05-2019, 03:03 AM   #18
af_1132
CB7tuner Member
Dang man, someone just bought the OEM unopened flywheel bolt!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
Old 11-14-2019, 01:59 AM   #19
af_1132
CB7tuner Member
Alrighty, someone nabbed the H22/23 auto tensioner from Gates!
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
