so i just purchased my new slotted/ drilled rotors but before i installed them i wanted to know if there is any bigger calipers i can install with CB rotors.
the reason i ask is because all the threads ive been reading require you to get bigger disk rotors in order to make the legend/ prelude/ vigor/ nsx caliper swap.
so if I'm correct cb7s have 10.3 inch front rotors
can i get any better bigger calipers for these rotors or is it necessary to switch rotors??
thanks
thanks
