1993 Honda Accord stalling problem plz help
    Originally posted by 90JDMACCORDEX View Post
    Im Having The Same Problem With My Car. It Ran Fine The Other Day And All Of A Sudden While Driving Down The Road The Motor Just Shut Off And Would Not Start Back Up. I Have Fuel To The Rail And I Have Spark. But It Just Wont Start. It Wants To Start But Wont. Today I Checked To See If The Timing Belt Broke And The Belt Is Fine. So What Could Be My Problem?
    Ignition switch harness.
      are you sure thats what it is? because again i went outside to start it and it started for a second and then shut off
        Do the dash lights go out when it shuts off?
        My 5.7 LS1 Holden Ute
          no everything stayed on. the engine just shut off
            I like the ignition switch on this one... turn the key to start, car cranks, but will not fire, or if it does, it will die immediately... but if you carefully bring the key back, don't let it spring back on its own, hold it as it comes back from start, and the car stays lit, you have a bad ignition switch. My wife's cb7 with a mere 43,000 miles, did it to me 3 months ago. I held the key in the right position and made it home. Swapped the switch (the electrical portion) and problem solved. I highly recommend you buy the Honda switch... more money but much better than aftermarket. This is a common problem with many Honda cars. My 91 DA did the same thing, and when I used to sell Honda parts we went through a lot of them. As a general rule, on Honda vehicles and electrically speaking, ignition switches, main relay(same as a PGM-FI relay) and igniters will leave you stranded.
            Good luck
            1991 Accord Ex Black/Tan... bone stock 45,000 miles
              im thinking its the ignition switch because the car started fine and then all of a sudden when i went to drive it i went 3 miles and it drove fine then all of a sudden it shut off and wouldnt start back up
                Originally posted by JunyAccord View Post
                My distributor was leaking when it my car used to stall. I replaced that along with the Idle air control valve. Ran fine for a little while.
                Recently i noticed bogging, and when i pulled my spark plug wires off there was oil in the tubes. So now i have to change the valve cover gasket, upper and lower rings, and the spark plugs. Check all those i mentioned.
                Ya... mine was the distributor. i must have had a short in it cause it crapped out at totally random times. My mechanic had no idea what was wrong though.
