Rear timing balancer shaft gear 's timing mark
huh? To set timing on h22a makes sure bioth cam gears are pointing straight up and align the crank on the bottom with the dot...You havent installed your balance shaft by the looks of it too.
Originally posted by NAiL05huh? To set timing on h22a makes sure bioth cam gears are pointing straight up and align the crank on the bottom with the dot...You havent installed your balance shaft by the looks of it too.
