Grumpys93 : 1993 Accord LX
    So did a little work today, nothing major. I finished up the wire tuck in the engine bay. I also mounted the alternator bracket, driver side bracket and cleaned up the garage. Now time for pictures.
    I need to pull the car out to scrub and degrease the engine bay.
    Then I have to decide on what I want to do about the driver side mount. I am getting annoyed with these mounts. Not sure if I should grind the bracket to fit the hump, put washers in between the bracket and mount or just say screw it and go back to my DIY poly mounts.
    ~Nick~
      I just cut that corner out of my mount bracket with a hacksaw. I've had no problems with it.
        Go with DIY poly mounts!
        http://www.energysuspensionparts.com/diymmi
        MRT
        Selling on Ebay!
        15.10 @ 90.42mph
          I will probably do this and see how they hold up.
          Originally posted by af_1132 View Post
          I already have poly filled mounts that I used on my last set up. I just wanted ESP mounts for the bling factor. My poly mounts aren't pretty but they are super strong. I will probably give the ESP a try first since I spent the money on them.
          ~Nick~
            I might have to try that diy poly, my esp insert is falling apart on the driver side.
              I wonder if there is a way to fill the ESP mounts. I know I would have to come up with a jig to hold the sleeve in place. I might try it.
              ~Nick~
                Well I had some spare time today so I port matched the plenum to the throttle body. The pictures are kind of hard to tell, but I took a straight edge to make sure the 70mm goes all the way through the plenum.
                So the intake manifold is 75% complete. I still have to install a couple sensors and buy injectors, fuel pressure gauge and regulator. But money is tight so I am just going to focus now on cleaning the engine bay and transmission.
                ~Nick~
                  Yesterday I bleed the brakes with the help of my wife, so now I can stop the car from rolling if it ever gets out of the garage. I also started to clean the engine bay, I got half way through it but plan to go over it again after I finish the first round of cleaning. Looks pretty good if I do say so myself, Can you tell which side I did first? Sorry for the crappy blurry picture.
                  ~Nick~
                    driver side , I win. Winner winner chicken dinner.
                      Awesome car .... i like ur choice for f22b.
                      a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed
                        Nice work on the porting of the plenum. I need to do that on one of my spare intakes. Also with the wire tuck and the cleaning it's starting to look really nice. The intercooler looks mean in the mockup on the jack.
                          This will be my last update with pictures for about 2 months or so. But I did finish up the driver side wire tuck today.
                          I have identified all the plugs and wires except this one. Not sure what it goes to maybe you guys can help. It has 3 brown wires and one ground going to it:
                          I put the headlight back on and decided to take a picture of the front end with the front bumper and without:
                          Lol you did the same thing i did.
                          Did you do the passenger side?
                            @jaykilla Yes I did the passenger side as well. I may still tuck the fuse box, but I still haven't made up my mind.
                            Yesterday I finished cleaning up the engine bay, now I need to find someone who welds to fill holes. I also removed the seats to give the interior a decent clean. I plan to remove the carpet and backseat later. But I did vaccum it all out.
                            Before:
                            After:
                            ~Nick~
                              Started working on the manual steering rack conversion today. I didn't get very far though. Halfway through the tear down and cleaning process, I had to stop to make dinner for the family. Hopefully this weekend I can finish it up.
                              Only got two pictures today.
                              Dirty rack and pinion:
                              Semi clean rack and pinion ( this was before disassembling it):
                              ~Nick~
                                It's a great start to the project! Looks good and you should be happy with the result.
