i have searched but couldn't find . i see a lot of pics of the timing belt exposed. can the upper and lower timing covers be left off. will it hurt anything?recommended?
timing cover deletion
Originally posted by marvin75 View Posti have searched but couldn't find . i see a lot of pics of the timing belt exposed. can the upper and lower timing covers be left off. will it hurt anything?recommended?
Originally posted by Raf99 View PostIt's for show. Technically they are taking a chance. Slim chance, but it is there.
A budy of mine put an AEM gear on the end of his cam and cut the top of the cover off. He got some water on the belt and it slipped a notch. I wouldn't do it unless your car is strictly for showProcrastination is a THIEF of time!!
MY MRT
http://www.cb7tuner.com/vbb/showthread.php?t=203992
My First CB7
http://www.cardomain.com/ride/705233/1990-honda-accord/
Originally posted by marvin75 View PostWill it hurt anything?
On a show car, yea it can be done (Still with risk)
On a daily driver - Its just dumb to do (and there is actually no genuine need to), Seriously why?
Just, So you can see a spinning cam gear once every now and then?
My 5.7 LS1 Holden Ute
It's left off on occasion so when you stop to get gas you can retard the timing of your cam because it's so hot out. That's the best reason I can come up with. I would wager most of the cover deletes you see are because they broke it or lost the bolts upon install of the engine/timing belt.....
Now remember on my 91 civic si the timing belt cover would hit the hood with my zc motor swap. I put washers on my hood hinges, all my friends left the timing belt cover off on their cars.......father in law has it back again. Time to shine
Nice way to look at it!
Your ECU will adjust the timing accordingly for outside temperatures, though...lol I'm pretty sure most of the pictures you see of open timing belts is merely for show/bling. it serves as no mechanical gain to do so. As mentioned it will actually prematurely wear out your belt and possibly cause catastrophic failure if a larger piece of debris gets caught up in there.
If you need to access an adjustable timing gear you could cut a small hole in the timing cover. At least that way it will greatly reduce the possibility of debris getting inside.Last edited by GhostAccord; 05-25-2014, 10:17 AM.
