I wasn't satisfied just installing a fully functioning digital climate control so I had to modify it. Now I control it from the cruise control switches. With cruise master switch on= auto, off, mode. With cruise master switch off=temp up, temp down, and fan.
lucifer1 : 1990 Accord LX
Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
The amount of cool little mods in this car is amazing! What sort of work do you do for a living?
I love how none of it is too intrusive on the original design, but they're all subtle things/oem parts that all add up to make the car something totally different. Can't wait to see the paintjob when it's finished!
hey brother I fixed my window after going back through the post and reading them a little closer i went and flipped my damn window lock switch AND WHAT DO YOU KNOW!!!!!! it was the damn switch the whole time. I'm kinda Pissed and glad at the same time and feel a bit stupid !! Thanks for the help my friend and i would like to show you some of my Blue LED's that i have integrated in to the dash components. once there done i will make a MR. but if you have any good advise or idea or tips i'm up for suggestions.Last edited by tonka9999; 02-08-2012, 11:40 AM.
After reading Tippey's DIY for heated mirrors,I wanted to add them. Mainly since my mirrors were already apart for painting but So Cal winters can get so harsh you have to wear pants sometimes. After many trips to junkyard, I finally found a 1st gen TL with heated mirrors. I disassembled them and compared them to an accord while at the junkyard at they looked to match completely. So I took the glass and motors only. I did not get what year the car was, but the mirrors were the bumped out back versions.
After getting them home, I pulled apart the accord motors and they are identical except for colors and wire terminals. I simply mounted the heated baseplate/glass on the accord motors. Then I soldered on the terminals so it will wire up in the connector. Alternatively, the whole heated motor/glass assembly will bolt into the accord mirror bracket but the motor wire terminals need to be changed.
Comparison of the motors and glass
heater wires with terminals
wired up to the connector
finished
Use a cl, tl, pilot, crv, civic, or accord heated mirror that is the same shape. Newer models are lighted. I am using an rsx switchManual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
picked up a power seat.
Where's the side panel with the switches?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I am going to try to put the accord foam and covers on the cl seat
I took the switches off so they would not get beat up.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Stop stop stop. This ar is sick man. Happy 4 u. I alwaysssssss wanted to do the light up door handle thing. Can you please go into it alil more how u did that... are the leds connected to the door switc?**Blk Housed Slut Crew Member #1**
any pointers on the led door handle, wat kind did u use?**Blk Housed Slut Crew Member #1**
I just wanted to comment that your playing on a whole different level than most of us. Everything is just so subtle and awesome. I am love the attention to detail that you have, and the ideas that you are able to bring to life. Great work.
Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
The Caravan 2015
MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
