Go Back   CB7Tuner Forums > Site Features > DIYs > Suspension DIYs
Old 07-17-2011, 12:16 PM   #1
Cb_JoeyG
Contributing Member
Cb_JoeyG is cool... so far.
Susp: Installing front SPC Balljoint camber kit
Well i finally got around to installing my camber kit last night.. Pretty straight forward affair. Very High quality parts for being made in china
But considering this is the best camber kit for the front of our cars
Tools needed:
10mm, 17mm, Needle Nose, Hammer, and a Vise or press
Upper Arm Removal Process
Step 1:
Step 2:
Step 3:
Step 4:
Useing the nut from your old ball joint (flipped upside down for better strength) Hit the nut with a hammer until she pops loose
Alt Method: Use a pickle fork or other form of balljoint seperator
Step 5:
Remove the upper arm nuts in the engine bay
Like this..
And pull your old arm out
Like so!
Now the fun begins
__________________
8 Accords so far:
'81 SE Sedan(1st Gen), '83 SE Sedan(2nd Gen), '89 SE Sedan(3rd Gen)
'89 DX Sedan(3rd Gen), '92 LX Coupe(4th Gen), '92 EX Wagon(4th Gen)
(3rd gen parts car) I'm currently Driving a '14 Accord Sport 9th Gen
Cb_JoeyG is offline   Reply With Quote
Old 07-17-2011, 12:17 PM   #2
Cb_JoeyG
Contributing Member
Now i had removed the balljoints from my extra arms a few days previously so i had time to prep and paint them..
To remove the balljoint;
Scrap all the crud and dirt off it.. And find/remove the snap-ring keeping it from coming out.
Using the triangular hole in a jackstand (NOT the ones holding up your car!!!) I had that to hold the arm while i pounded the balljoint out with a hammer.. A socket about the size of te Bj eases removal
I already have poly bushing so i transfered my anchors from the old arms to the new ones
Installing camber plate
So heres your arms. Bare!
And heres your camber plate
Step 1:
Line the slot in the camber plate up straight with the hashmark/notch in the control arm
Step 2:
Put it in a vice and clamp her down as straight as you can
Step 3:
Remove arm and insure that the plate was pressed down properly/straight.
Step 4:
Put the Rest of the camber kit together
Note: Be sure to recognize which way the balljoints are facing, One way is for positive camber and the other is for negative
So here it is side by side with the old one
So now just reverse of removal! Toque the baljoint bold to spec, of in my case German Specs- GootanTight
And heres your final product!
Now go get an alignment!
I recomment STRAIT ALIGNMENT in Port Angeles, WA!!! =]
__________________
8 Accords so far:
Old 07-17-2011, 02:05 PM   #3
Lynx
CB7tuner Member
Lynx seems to have made some friends!
Send a message via MSN to Lynx
Very nice DIY writeup dude!
__________________
My FB Page - http://www.facebook.com/hellaflush3d
My 3D Work --> http://samauripizzacats.deviantart.com/
Lynx is offline   Reply With Quote
Old 07-17-2011, 02:55 PM   #4
Cb_JoeyG
Contributing Member
Thank you sire twas my first
__________________
8 Accords so far:
Old 07-22-2011, 07:55 AM   #5
Noridetoolow
CB7tuner Member
Noridetoolow is cool... so far.
GOOD STUFF!! I was wondering about this and this was a major help!
reps 2U!
__________________
Bought from Darkcloud
http://wheelflip.com/r/DrAkE
Noridetoolow is offline   Reply With Quote
Old 07-22-2011, 09:53 AM   #6
Jack_lee
CB7tuner Member
Jack_lee is cool... so far.
nice write up!
is there any hitting after install?
__________________
-My Member Ride thread-
-JL store-
Jack_lee is offline   Reply With Quote
Old 07-25-2011, 10:48 PM   #7
Cb_JoeyG
Contributing Member
Nothin knocks at all yet... but i gotta adjust theseeee a bit to test it out
Hahah but thx alot guys i appreciate the comments.. It was my first DIY i shoulda done one for the coilover install and i still might
__________________
8 Accords so far:
Old 07-28-2011, 11:06 AM   #8
Jack_lee
CB7tuner Member
i heard the FnF has a good ride....
well,keep us updated later.Thanks !
__________________
-JL store-
Old 07-31-2011, 07:29 AM   #9
speedfr3ak
CB7tuner Member
speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire.
ahhhh ur ok we all can install coilovers! lol but nice work and for actually building a car correctly people in my area are lost with camber duhhhh whats a camber kit thats my neighborhood. well the tuners
__________________
Quote:
Originally Posted by deevergote View Post
This thread is over a year old, you fucking retard.
i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
speedfr3ak is offline   Reply With Quote
Old 07-31-2011, 07:31 AM   #10
speedfr3ak
CB7tuner Member
yea u like that set up/
__________________
Old 08-18-2011, 03:09 PM   #11
Cb_JoeyG
Contributing Member
Heh yea coilover installation isnt exactly hard.. I also recient installed my SPC rear upper control arms.. No real good pics of them yet tho, Mayb ill take some next time i rotate tires
The ride is awesome! I love the coilovers.. Plenty agressive and not to stiff. I get the three wheel motion alot when going sideways into my driveway too Thats how you kno its stiff enough!
__________________
8 Accords so far:
Old 03-19-2013, 12:39 PM   #12
Cb_JoeyG
Contributing Member
Figured i might bump this thread in case ppl are buying these. Ive had a few guys ask me about them lately and even had 2 order them because of me.
I also have all the pics from my install of the extreme angle kit on my wagon if anyone needs them, ill post pics when i get a few mins
__________________
8 Accords so far:
Old 03-19-2013, 12:45 PM   #13
domesticated
CB7tuner Member
domesticated seems to have made some friends!
Assuming doing it this way you don't have to grind your control arms down? The problem I'm having with my Ingals kit is it pushes the control arm out instead of the ball joint and I had to grind then ends down to prevent them from hitting my body. I have brand new upper control arms. But maybe I should switch out these.
__________________
'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing - Chassis Dynamics Data
domesticated is offline   Reply With Quote
Old 03-19-2013, 01:44 PM   #14
faqncb7
CB7tuner Member
faqncb7 is cool... so far.
Great write up lots of details.
faqncb7 is offline   Reply With Quote
Old 03-19-2013, 01:46 PM   #15
Cb_JoeyG
Contributing Member
No grinding necessary
Thx, I have a lot more with my wagons install process
__________________
8 Accords so far:
Old 03-20-2013, 11:51 AM   #16
DanCan
CB7tuner Member
DanCan is cool... so far.
Yup, I`m 1 of those 2. This will definitely help when it comes time to install my kit. Was shipped and delivered super fast, I still need to go drive and pick it up. Probably on the weekend.
Good stuff Joey, nice write-up. Reps
__________________
Project:Black Skittle
AOM->April 2014
MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
DanCan is offline   Reply With Quote
Old 03-20-2013, 03:21 PM   #17
Cb_JoeyG
Contributing Member
Yeaa buddy, no problem glad I could help
__________________
8 Accords so far:
Old 03-21-2013, 09:43 PM   #18
AmznAzn
CB7tuner Member
AmznAzn is cool... so far.
Quick question, when you pressed it they stayed in right? When i tried pressing mine (used a ball joint press from advance auto instead of a vice) it wouldn't stay in. also how did you align it? I had trouble finding the exact center of the plate.
Mine knocks on moderate to harsh bumps, must've done something wrong
Nice write up btw!
__________________
^MRT^
AmznAzn is offline   Reply With Quote
Old 03-22-2013, 10:13 AM   #19
toycar
CB7tuner Member
toycar is very helpful toycar is very helpful toycar is very helpful
And people say you cannot replace the upper ball joint w/out replacing the entire arm.
Lol
__________________
Quote:
Originally Posted by wed3k View Post
toycar is offline   Reply With Quote
Old 04-26-2013, 10:15 PM   #20
Quashish
CB7tuner Member
Quashish seems to have made some friends!
my stock ball joints are just stupid! wont come out for anything with a hammer + pb blaster.
also was it the energy suspension poly bushings you have in your anchors? i got some and am stumped on how to get them in there.
i took the old center rod out
and thought the rubber was just in the way but when i took most of it out
i saw that the bushing is bigger than the hole so i thought maybe the metal ring was removable
but its all one piece??
i suck at this
__________________
C-3PO's MRT USDM yo!
Quashish is offline   Reply With Quote
