Old 01-19-2016, 09:36 PM   #1
brsteinbach
CB7tuner Member
brsteinbach seems to have made some friends! brsteinbach seems to have made some friends!
Passenger Side Bad Shake When Moving Over 5mph
I just did my 5 speed swap on my Accord and I am using the 5 speed rear mount and the 5 speed conversion mount from Inovative and I am getting a horrible shake on the passenger side when going over 5 mph. Is it because I only have the one solid mount?
I'd appreciate the help.
Thanks.
__________________
Click picture for MRT
Sparkin CB7
brsteinbach is offline   Reply With Quote
Old 01-20-2016, 02:04 AM   #2
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
you did something very wrong, and your mounts aren't likely to blame. could you post a picture of the swap mount installed in the car?
__________________
Quote:
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 01-20-2016, 01:23 PM   #3
brsteinbach
CB7tuner Member
I can't get pictures at the moment. But I am 100% Positive that it is the right mount. What else could cause it bud?
Edit: The engine is in the right position, i's not too far forward or back.
__________________
Sparkin CB7
Old 01-20-2016, 01:52 PM   #4
cb9love
CB7tuner Member
cb9love is cool... so far.
How old is the cv axles your using?
I have had cv axles that were going out cause mysterious vibrations in my wheels, usually just under acceleration.
__________________
CB7TUNER.com
Educating each other one car at a time.
cb9love is offline   Reply With Quote
Old 01-20-2016, 02:39 PM   #5
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
Are you using the correct axles? Are they pushed all the way in?
__________________
deevergote is offline   Reply With Quote
Old 01-20-2016, 08:36 PM   #6
brsteinbach
CB7tuner Member
Quote:
Yes, at first I had the wrong axle's but I ended up buying new one.
I am so confused.
__________________
Sparkin CB7
Old 01-20-2016, 08:50 PM   #7
brsteinbach
CB7tuner Member
Quote:
What do you think could be "very wrong" just curious cause I need of help badly.
Thanks.
__________________
Sparkin CB7
Old 01-20-2016, 08:56 PM   #8
brsteinbach
CB7tuner Member
DSCF2195 by Brian, on Flickr
DSCF2194 by Brian, on Flickr
DSCF2193 by Brian, on Flickr
DSCF2192 by Brian, on Flickr
DSCF2191 by Brian, on Flickr
DSCF2190 by Brian, on Flickr
That is the Inovative conversion mount 70a polyurethane and the rear mount is from the donor car so that is for sure a 5 speed mound.
__________________
Sparkin CB7
Old 01-20-2016, 09:10 PM   #9
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
cp[mike] is very helpful cp[mike] is very helpful cp[mike] is very helpful
just to eliminate potential problem points, swap the wheels/tires around and see if the problem changes sides.
also, have you tried jacking the front up and letting the wheels spin? see if anything is obviously out of alignment while its moving.
is it possible you damaged the hub while removing/installing the axles?
__________________
cp[mike] is online now   Reply With Quote
Old 01-20-2016, 10:08 PM   #10
brsteinbach
CB7tuner Member
Nope, she's all good. I have it up in the air with the wheels off and it still shakes like a mofo. I too a couple videos I will post soon. It is soo damn weird. I have a feeling since the original rear mount that I am using are over 200k miles that it maybe on of the big problems. I am so dumb founded. I'll post the vids. Don't mind me if I seem a little off, I've been having a few drinks tonight lol.
__________________
Sparkin CB7
Old 01-20-2016, 10:27 PM   #11
brsteinbach
CB7tuner Member
Video's, coming soon. Sorry for the poor quality, but they work.
__________________
Sparkin CB7
Old 01-21-2016, 09:07 AM   #12
brsteinbach
CB7tuner Member
https://www.youtube.com/watch?v=w1RZMJN5bSM
https://www.youtube.com/watch?v=_eM5Z1nU1J0
__________________
Sparkin CB7
Old 01-21-2016, 10:25 AM   #13
Accord problems
Contributing Member
Accord problems is cool... so far.
Could the input where the shaft on that side of the transmission be worn out or off set ? Just curies as to this .
Accord problems is offline   Reply With Quote
Old 01-21-2016, 05:14 PM   #14
brsteinbach
CB7tuner Member
Quote:
Like does the axle seem loose on the passenger side input side? Not that I notice. I moves maybe a millimeter but that's it. I am so lost. I do see when it is shaking it is putting stress on the drivers side mount and especially the rear mount. I am guessing the mounts are over 200K miles so I was thinking about doing the window weld method to see if that helps.
Thanks for the reply.
__________________
Sparkin CB7
Old 01-21-2016, 05:18 PM   #15
cb9love
CB7tuner Member
Please don't use the window weld it is worse than duck tap on a split finger at the job site.
Use this instead. It's a good DIY method and relatively cheap and easy.
http://www.energysuspensionparts.com...nt-Inserts.asp
link fixed
__________________
CB7TUNER.com
Old 01-21-2016, 05:47 PM   #16
oni_cb7
CB7tuner Member
oni_cb7 is cool... so far.
link fixed
Window weld is a liquid urethane. The link you posted says to use liquid urethane.
What's the difference?
oni_cb7 is offline   Reply With Quote
Old 01-21-2016, 05:50 PM   #17
cb9love
CB7tuner Member
the durometer rating.
__________________
CB7TUNER.com
Old 01-21-2016, 05:52 PM   #18
cb9love
CB7tuner Member
that ,and a two part epoxy will always be greater than a one part epoxy
__________________
CB7TUNER.com
Old 01-21-2016, 06:05 PM   #19
oni_cb7
CB7tuner Member
Well, 3M Window Weld is 60A, the lowest recommended urethane on the link you posted. However, I didn't see anything mentioned in that link about 2-part epoxy, so I didn't think that was included with what you mentioned originally.
Old 01-21-2016, 06:13 PM   #20
cb9love
CB7tuner Member
One part epoxy's are used in situations where using a two part epoxy would be impractical and the lesser one part epoxy will serve in it's intended use.
__________________
CB7TUNER.com
