Well Ive worked my A@# off on my sons 91 SE. He needed both axles, master cylinder, major tune up, oil change, and a few more things to get him running strong. I got everything done. Car drives and stop very good now. only problem I got is an anti lock indicator light on. I know that has to do with the anti lock braking system. which component would be at fault first. I see that there is another brake resivour on the left side of the engine bay near the fuse box. could that be the problem?? How about the sensors that are attached to the steering knuckle??? How about the ABS motor????
ABS Light on 91 SE
You can diagnose an ABS light just as you can a check engine light.
http://www.cb7tuner.com/vbb/showthre...light=abs+code
Hope that saves ya some time and money. Good luck
Originally posted by C91BLX7 View PostIts almost 95% of the time any ABS problem on any vehicle is the wheel sensor.
They are about $100 to replace though.
Originally posted by nine_deuce View PostYou can diagnose an ABS light just as you can a check engine light.
Hope that saves ya some time and money. Good luckkiss my grill
Members Ride
