Temp Gauge Stuck on Cold
    I was driving home today and noticed that my temp gauge didnt move from Cold at all. I installed another temp sensor(the 1 wire sensor) that was from my sons 91 SE. I still have the same problem. I did noticed that the gauge will drop just an 1/8 of an inch when i start the car. Should I swap gauge clusters?? I do have another cluster lying around. Do anybody have any ideas?????
    Try checking your thermostat. I was experiencing the same problems as you. My thermostat was stuck open. Also, if you experience lack of heat, it could also be you thermostat.
      I changed the thermo when I found out that the swapped temp sensor didnt fix the problem. Im thinking the actual gauge on the cluster died on me. Has anyone else experienced this situation?????
        I also grounded the 1 wire plug to see if the temp gauge move and it didnt.
          I'm a mechanic and I've replaced the temp gauges in accords several times.
          the diodes go bad or something. I think there might even be a TSB.
          if you grounded the sensor wire and still got nothing then you probably need to try swapping clusters unfortunately.
            I was thinking I needed to replace the cluster. It just that I got 98,076 miles on it. I know clusters in the J-yards are going to be way over 150,000 miles on them. Is there a way to roll the odometer back on the cluster from the J-Yards to reflect what my miles actually are???? Is this illegal????
              you can swap just the temp gauges.
                When you say swap temp gauges, are they just screwed to the ckt board??? They are not soldered to the ckt board?? I have an extra junk cluster Ive been playing with. Im going to check this out. Thanks!
                  it isnt the gauge...its the temp sending unit.
                  its a piece sticking out of the motor on the passenger side! go to advance auto parts, they have them available new
                  smoke tires, not drugs.
                    Ok! I SEEThere are 3 screws holding it in! Im going to hit the J-Yards and pick up a few temp gauges! Thanks!
