I am wondering if the headlight bracket that the headlight, corner light and fender mount to is the same on 90-93? I see that the lights are different from 92-93 but I'm not sure about the bracket. I have a 92 and the only car I was able to find with an intact bracket was a 90. Also, what's the different between the 90-91 and 92-93 front ends? Thanks.
Headlight bracket compatibility?
Yes, the brackets are the same 90 through 93. www.hondaautomotiveparts.com is a good place to check compatibility between years. If you select a part number, there is a tab that shows all the vehicles it fits. There is even a price listed for the brackets, so you may even be able to buy a new one from Honda.
Headlights, corner lights, grille, bumper, and bumper lights are different. A little searching would have found this: http://www.cb7tuner.com/vbb/showthread.php?t=21193Last edited by Fleetw00d; 05-06-2020, 11:39 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
