Compressed nitrogen bottle. Whats it used for?
    I got a large bottle of compressed nitrogen gave to me today. Its a bottle like what is used for Oxygen Acetylene torches.
    It has a green label that says: Compressed Nitrogen UN1066.
    I have searched on the net and the only uses I can find is medical, inflating tires, and HVAC stuff.
    If I cant refill it with Oxy or Ace I don't want it. I'm searching for uses so I can hopefully find a buyer by knowing who to market it towards.
    I believe its full as its heavy as can be. Its about 5 foot tall I would say.
    The bottle says something about medical use and being from Kansas City.
    "Great spirits have always encountered violent opposition from mediocre minds." -Albert Einstein
    We use them at work to refill accumulators. You can always use it and possibly trade it for an oxygen or acetylene tank at a gas place.
      Laughing gas...
        Originally posted by wildBill83 View Post
        Laughing gas...
        I'm pretty sure you're thinking of nitrous oxide.
          Yep.
          I use it a lot at work for purging out piping in chemical plants. It's a good inert gas that drives oxygen/air/other chemicals out of the plant.
          Other uses include filling bags of food prior to shipping. The inert nitrogen keeps the food better longer.
          The connections on the top of the tank are nitrogen/argon specific, and you cannot use a regulator for oxygen, etc with this bottle.
          See if there is an AirGas supplier local.
            Nitrogen + oxygen = nitrous oxide
              Originally posted by wildbill83 View Post
              nitrogen + Oxygen = Nitrous Oxide
              N2o ≠ N2o3
              MRT
              sneaky motherfucker
                is it one of the more narrow bottles or one like we have at my job below?
                we use the smaller bottles when this one is getting filled actually.. i work in polyurethane manufacturing and we use it because its heavier than oxygen and it helps prevent the resins we use from air curing.. we have a line fed to each one of those tanks to help push the resins and other chemicals out of the valves we use to weigh up the proper grams for each pour..
                  Maybe a nearby moto track purveyor would purchase it,to fill the guys shocks
                    Ok thats good news.
                    Laughing gas...
                    That would be nice. Jk.
                    It says not to inhale or anything. It says something on it about it not being dangerous, just not to inhale it. And something about what to do if you stop breathing after inhaling it.
                    Originally posted by AccordWarrior View Post
                    Yep.
                    We have PG Walker in Springfield which is not to far from me.
                    While trying to see all of its uses I came across Nitrogen specific regulators.
                    Its a smaller bottle that looks identical to an oxygen bottle for a cutting torch set up.
                    I did come up with something about plastic welding/urethane welding along with my search. I did not read into it too much because it sounded over my head.
                    I will keep that in mind. Like I said I got it for free and I couldn't turn it down. A friend of a friend had it in his garage and said yesterday his neighbor moved and asked if he wanted it. He took it and turned around and gave it to me at a party last night/ this morning.
                    I'm really glad its not something I am not supposed to have as that did cross my mind.
                    I'm sure driving home with it in my trunk/backseat area sticking out the trunk was illegal as hell. I really had no other way to get it other than folding my back seat down and sticking it in there.
                    Hellraisin was there last night at the party as well and said he thought a license was needed to transport it or at least for it to be chained down.
                    With that being said how the hell do I transport the thing? Is it bad to get caught with it in my trunk?
                      You can use it to fill your tires too, nitrogen is less corrosive than compressed air. Yeah I was just kidding about the nitrous oxide, don't try it!
                        honestly not sure about the legality of transporting it.. we get ours delivered by AirGas (large and small tanks) and they pick up our empties.. i am pretty sure that just having it laying in a car isnt quite safe either.. if someone hits you and the valve ruptures, youll be in some shit.. obviously the large one is wide enough not to tip over, but the smaller ones are kept in a small "cage" type area where they cant tip over.. if we use one of the smaller ones, a chain is wrapped around the valve and anchored to the resin tank next to the nitrogen tank in my pic above so it doesnt fall over..
                          Same as in our facility. They're chained together with a cap over the valve assembly.
                          OP, the reason you cannot inhale nitrogen (if you didn't already know...apologize if I'm stating the obvious) is that you can suffocate yourself.
                          I wonder what pressure the bottle is at, I'm thinking probably 2000 psig.
                            maybe sell it to a minitrucker. there are a ton in the springfield/branson area and a nitrogen setup is initially cheaper than buying compressors and a tank.
                              Sell it to a mech in the aviation industry. They use nitrogen in the tires and shocks for some jets/aircraft.
                              -1992 CB7 EX w/H22 [sold 10/09]
                              -2005 Legacy GT limited [current]
