I am interested in swapping my stock steering wheel for a TSX s/w. Are there any videos of step by step instructions DYI?
TSX Steering Wheel Swap
You need to swap a CD Accord column in first. CB columns are the wrong splining. CD columns have the correct spline count (33) I think for newer steering wheels to fit on. Then there’s the clock spring and the MDX combo switch holder. I think I used the CD Accord plastics around everything. Idk what plastics will line up perfectly with the ignition. I have a push button start so my whole ignition lock cylinder is removed. My mrt has pics of the setup.5 studded & leather clad - Praise The Lowered
~Mark~
I used the center airbag from an 03-07 Accord Coupe in my TSX wheel so yeah they are at least very close in looks. I used a clock spring from the same year Accords also but to get everything to lock together you need an 01-06 Acura MDX combo switch holder. Read my mrt. There’s more info and pics there.5 studded & leather clad - Praise The Lowered
~Mark~
I went thru your mrt after I saw this post, even watched the YouTube video of your car, you've done a lot of remarkable upgrades and I wanted to comment directly on your mrt, but I'm still in thread post purgatory! Ha thank you for putting in the years of MDX that you used, some of your DIY is lacking that info in your mrt. I'm not knocking your stuff, but it makes it tougher on the new guys that aren't fluent in all the interchangeable parts. Plus, there's not as many Acuras as there are hondas in my PAP. Thanks again and sorry if I hi-jacked, just looking for more clarification.
