Marathon session yesterday: timing belt, water pump, tube well seals, oil pan gasket. Had a heck of a time getting the crank seal out. Triple checked the alignment of balance shafts. Couldn't easily get the gasket off the pan; used a spare pan I had. All three studs came out of the exhaust manifold; I think I'm just going to put it back together with bolts instead of trying to put studs in from underneath.
Chased the threads with a tap. Installed flex pipe to manifold with stainless bolts.
