Ok so it's been a while since I've updated this. Not much has changed as I have been unemployed and busy with my band. I have a job now though and have done a couple little things.
I painted my stock grill, I think it looks good:
I started on my Glove box radio idea, and change my shift knob:
Removed my rear seats for when I took my brother to GA and we picked up a front bumper, trunk lid, radiator, and radiator support:
Put the four best tires I had on my car until I can get some new ones for my TSWs (TSW fronts, oem steelies back lol):
Aside from these updated, I am trying to decide what to do about my side molding. It was screwed in and had silicon or something gluing it in instead of clips. o.O So Idk whether to take the side molding off or try to get some new ones. I also need a new front bumper. I will be removing AC and PS soon. More updates to follow. Unfortunately I won't be getting low for a couple months it looks like though
Clean DX! I like the hideaway radio and upgraded front. Are you keeping the rear 90-91 or switching to 92-93?
Thank you sir! More clean-ness will come when I get around to the engine bay, and can clean the tar out and whatnot. I think I will be painting what isn't covered in carpet or anything black in the back seat/trunk area.
The radio was something I had been thinking about for a while, but finally grabbed the Dremel and went for it today.
If by rear you mean tail lights, I will be keeping the 90-91 for now and smoke them a little in the amber area. Only way I'd go to 92-93 would be a CF trunk.
Decided I will be taking two of my wheels to get sandblasted on Tuesday. I sanded down one of the wheels by hand a little and tried on a color:
Next to the car:
I think this satin white is a good color for these wheels on my car.
The process I will be using is going to be as follows:
1. File and sand any major curb rash or other areas
2. Strip paint off with Aircraft Remover
3. Degrease with Simple Green
4. Dry
5. Two coats Self Etching Primer
6. Sand with 320 grit and wipe with micro fiber cloth
7. Two coats Self Etching Primer
8. Sand with 320 grit and wipe with micro fiber cloth
9. Two coats Filler Primer
10. Sand with 320 grit and wipe with micro fiber cloth
11. Two coats Filler primer
12. Sand with 320 grit and wipe with micro fiber cloth
13. Clean with Simple Green
14. Dry
15. Two coats Krylon Satin White regular spray paint
16. Sand with 320 grit and wipe with micro fiber cloth
17. Two coats Krylon Satin White regular spray paint
18. Sand with 320 grit and wipe with micro fiber cloth
19. Two coats Dupli-Color Wheel Paint clear
20. Sand with 320 grit and wipe with micro fiber cloth
21. Two coats Dupli-Color Wheel Paint clear
I don't know a whole lot about wheel painting, so if you have any suggestions of how to make the wheel come out better I am all ears
