ok... heres the deal... just last week i ran a can of seafoam through the vacuum line, it stalled out the engine and sucked more in... went to start it and disasters happened.
the motor from my parts car went in, fired up fine and everything, moves the car... all should be good
if the accelerator is pressed between ~1% and ~20% of the way down the car is very choppy and it is hard to keep it running. if i floor it though, it peels away fine. It almost seems like its running too rich.
just some notes...
- my car is a 92 LX auto (sedan)
- parts car is a 90 LX auto (coupe)
- the coolant gauge isn't working, reads zero.
- the connector on the left side of the engine (a 5-pin on the 92 and a 7 pin on the 90). All i did was make some jumper wires with terminals on the ends to jumper the same colour wires together. there are 2 more wires on the motor that i have no idea what they are for.
- it doesn't seem like its running too hot, but I'm pretty sure the coolant temp sensor plays a major role in the fuel/air mixture, if its readings are not present, the computer will sub in its own values to keep you running.
- i also did an A/C delete (i just cut the lines and removed the compressor, is there anything else i should have done)
thanks in advance... you guys are great
just some notes...
