Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive > Other Automotive Members Rides
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 11-03-2014, 06:37 PM   #81
H311RA151N
Gold Member
H311RA151N seems to have made some friends! H311RA151N seems to have made some friends!
Thank fuck... The nut was just loose. Going to put a seal in it though as it's leaking like a son of a bitch. Some of what appears to be leaking is PB Blaster from the U-Joint nuts.
I can turn the nut with my finger. Just what I wanted to find.
__________________
-----------------------------------------In The Tetons----------------------------------------------
H311RA151N is offline   Reply With Quote
Old 11-03-2014, 07:16 PM   #82
H311RA151N
Gold Member
Every truck I have gets the Confederate flag headliner. This one will be no different. I bought a bulk of 3'x5' Confederate flags a few years ago.
__________________
Old 11-03-2014, 08:47 PM   #83
H311RA151N
Gold Member
Valvoline 80W90 Dura-blend Synthetic for the T19 4 speed.
And a new water pump. I done a lot of digging and found out that the NAPA Tru-Flow water pumps are made by Gates.
Also some degreaser.
__________________
Old 11-04-2014, 12:28 AM   #84
2winRB25
CB7tuner Member
2winRB25 is cool... so far.
you lucked out. A rear end swap would have been expensive.
__________________
"Great spirits have always encountered violent opposition from mediocre minds." -Albert Einstein
2winRB25 is offline   Reply With Quote
Old 11-04-2014, 04:52 PM   #85
H311RA151N
Gold Member
Quote:
Yeah, about $1000.
I bought a Kat's block heater and a sheet of Mr. Gasket exhaust gasket to make a custom exhaust gasket as I can not find the one I need anywhere.
__________________
Old 11-06-2014, 07:11 PM   #86
H311RA151N
Gold Member
Spectra heater core. Motorcraft stater solenoid. Precision fuel pump assembly. Castrol Transmax ATF (for Borg Warner 1345 transfer case).
__________________
Old 11-07-2014, 01:20 PM   #87
H311RA151N
Gold Member
New brake master cylinder and brake booster. The box it's sitting on is my "standin' box". I need it to stand on to work on this truck because I'm short (5'8"). I shot at it a couple times one day and afterwards thought it would be a great box to stand on.
__________________
Old 11-07-2014, 02:27 PM   #88
H311RA151N
Gold Member
NAPA Brake booster and brake master cylinder installed.
__________________
Old 11-07-2014, 05:11 PM   #89
RyanD
CB7tuner Member
RyanD seems to have made some friends! RyanD seems to have made some friends!
Send a message via Skype™ to RyanD
seems like with every new vehicle you get its just non stop parts. I love it man. your doing a fine job
__________________
"The Salty Old Bitch"
F22a4, Manual (Auto lasted to 368k)
My MRT http://www.cb7tuner.com/vbb/showthread.php?t=194341
RyanD is offline   Reply With Quote
Old 11-07-2014, 05:51 PM   #90
H311RA151N
Gold Member
Quote:
Thanks Ryan. If only you were here to help me like old times.
__________________
Old 11-09-2014, 11:00 PM   #91
H311RA151N
Gold Member
The bad.
Where do I start...
I'm wore out. Too busy and nothing is going right. Or at least the things I'm stressed the most about anyways.
I dropped the rear tank today. Only to find Oreilly's sold me the wrong fuel pump assembly and they cannot get the right one. Neither can NAPA or Autozone.
The brass float was full of fuel from a pinhole is the reason for the fuel level sending unit not working. The gauge will move when I plug the assembly in and move the arm.
I tried brazing the float to fix the pinhole but with the fuel vapors inside and the heat it kept making a little hole in the solder. I tried so many times I ruined the float.
I just wanted to buy a new float and use the old pump and assembly but I cannot find any online at Autozone, NAPA, or Oreilly's.
I have thought about using something else that will float but nothing comes to mind. Other than cork which wont work.
So here are the pictures of this nightmare.
The good.
I tightened the rear pinion nut down to 140ftlbs which is what Ford calls for. It was 1 and 1/4 turns loose. Not a bit of slop what so ever now that it's tightened. So that's good. U-joint is good so I didn't replace it.
And I got the new heater core in. No pics of it installed but here is the old one.
__________________
Old 11-10-2014, 01:34 AM   #92
illinois_erik
CB7tuner Member
illinois_erik is very helpful illinois_erik is very helpful illinois_erik is very helpful
hmmm..take some copper pipe split it and hammer it into a sheet big enough to go over the area you chowdered (dunno if it will be big enough to weigh it down didnt see the damage) anyway SOLDER it on..brazing is like using a shotgun to remove a stuck fishing hook..way over kill..you might even be able to just flow solder all over the area thats messed up. .just plain old solder no need for the silver solder..post some pics too if you can maybe theres a better way to skin this cat. Im not sure how its attached to the arm, but I just thought too you could fab up a little container the size of the original float from some old radiator tanks that are brass, (im sure you got some laying around :P) seal it up with solder and youd be good. maybe dissect the the old float leaving enough meat thats factory attached to the arm and solder the new float to that.
__________________
illinois_erik is offline   Reply With Quote
Old 11-10-2014, 01:57 AM   #93
H311RA151N
Gold Member
Quote:
Idk what I did or what it's called rather. I got the map gas out, flux and electrical solder and without putting the flame on the float I heated it up until the solder would touch it and melt which didn't take long. But every time I tried a pinhole in the solder would develop. Eventually I burned a hole in it or the solder pushed through the float by barely touching it. Unfortunately the hole now the size of a pea is near one end.
From reading on the internet prior to messing with it I read people heat up the factory solder where it's two halves come together then once they are apart they then fix the pinholes. Once that's done the put the halves together then solder or braze the seam. I know very little about this kind of stuff. I would assume the float is done for.
I have two good floats from my old carburetor. I was thinking about using them somehow as I left them in gasoline completely submerged with sockets for 4 days before I tried rebuilding the old carburetor so I know they are good.
I cannot find even the part number for the pump I have anywhere. So I cannot even buy the right assembly. And I have today (11-10-14) to get the tank in and with the fuel level sending unit working as it's about to get cold.
Oh and I found out my shop is 17' 7" and my truck is 17' 8" long.
__________________
Old 11-10-2014, 03:51 PM   #94
H311RA151N
Gold Member
From my thread on Ford Truck Enthusiasts I received the following reply in regards to the engineering number:
E5TF-9H307-FB ID engineering number is not listed in the Master Cross Reference Catalog or the 1980/89 Ford Truck Parts Catalog, but...
There are only two possible pumps for this application: 1985/86 F250/350 460:
E5TZ-9H307-E .. Fuel Pump & Sender Assy / User with Aft Axle PLASTIC Fuel Tank / Obsolete
E5TZ-9H307-FA (replaced E5TZ-9H307-F) .. Fuel Pump & Sender Assy / Use with Aft Axle STEEL Fuel Tank (Motorcraft PFS-130) / Obsolete
No Ford dealer or obsolete parts vendor has any of these 3 pump/senders.
After 1979, Ford did not sell the float by itself, it was only available with the sending unit. 1979 and earlier is not the same!
So... I'm pretty much screwed with this deal. So I think I'm going to go fuel cell and be done with it. More $$$ but I'm sick of messing with it.
I could make a float but one day the pump is going to fail and I'll be right where I'm at now. Man this sucks...
__________________
Old 11-10-2014, 05:11 PM   #95
illinois_erik
CB7tuner Member
Yeah..I did some quick poking around using that engineer number and basically all those pump assemblies have been discontinued..sucks. what about retrofitting a newer tank/sender/pump from a later year..or one of the same vintage that is more common? Im guessing the general design hasnt changed much between years.. Well at least now you know what the problem is..Its blue and has a circle around it HAR HAR HAR...Hey I can talk shit about ford Ive at least owned one (84 Grand Marquis)
__________________
Old 11-10-2014, 05:25 PM   #96
H311RA151N
Gold Member
Yeah, damn old Fords!
I'm thinking along those lines currently. The design hasn't changed a whole lot between years really. One pump is close to the same design. I may try a retrofit or something along those lines.
I have a soft spot for Fords as that's what I was riding around in as a kid. But I like many makes and models.
__________________
Old 11-10-2014, 06:03 PM   #97
H311RA151N
Gold Member
I tested my pump and the fuel level unit again. Both work. Which I knew they did but before I put it back in I just wanted to make sure they still work. (Yeah, I hate doing things twice that much. Even though this isn't that hard.)
__________________
Old 11-10-2014, 09:16 PM   #98
H311RA151N
Gold Member
I have put all other projects aside, cleaned out the shop and rolled the truck in. It's cramped but it beats working in the cold. And I made it fit. Took the back bumper off. 17' 5" long without the rear bumper.
__________________
Old 11-11-2014, 03:00 PM   #99
H311RA151N
Gold Member
Quick Car 4AWG Race Wires battery cable kit came in today.
__________________
Old 11-12-2014, 12:52 PM   #100
wildBill83
CB7tuner Member
wildBill83 seems to have made some friends!
LOL @ the rear bumper, I was actually going to suggest the front bumper until I read that!
Screw working in the cold, we are in single digits to low 20s here right now. Snow is on the ground. Brrrr.
wildBill83 is offline   Reply With Quote
