I got a 92 ex coupe and i'm about ot replace the rear upper control. I know both of those ball joints are bad. What else should i replace while i am back there. Maybe the rear lower inner control arm bushing also? The control arm will be a breeze i think. But the bushing i think not. Do those go bad. It is hard to tell if bad compared to a ball joint. I would bet after 26 years it is bad. Any thoughts on this anyone? Also any other ball joints or bushings in the rear suspension i should replace. I did the front last year so it is mostly good.
Rear Control Arm Question
The bushings would be a pain especially at the point where the toe is adjusted especially if you live in the rust belt area of the country.
Overtime the bolts that hold those arms in place will get rusty and seize so it would require more than a days work just to get them out.
If I were you and the only thing you had was that car for a daily, I would see if you could find spare parts off another car and rebuild those.
I'd upgrade to a prothane kit since they last longer than the O.E rubber ones.
At least that's what I'm doing with my car.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
I'm not even sure you can get all the bushings (at least like OEM) for the rear lower control arms. I got the whole cross member and arm from a car with about 100,000 on it last year in FL for $18. Still haven't cleaned it up yet an installed it. Toe adjusters came out easy as you please (I know mine are seized, but the alignment is still pretty good). It is a good idea to get the whole set up, refresh that, then swap as an assembly and you don't have to worry if the pivot bolts are seized in yours.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by HenRoc View PostThe bushings would be a pain especially at the point where the toe is adjusted especially if you live in the rust belt area of the country.
So anything else to replace in addition to rear upper control arm and lower inner control arm bushing(prothane type).
Originally posted by fleetw00d View PostI'm not even sure you can get all the bushings (at least like OEM) for the rear lower control arms. I got the whole cross member and arm from a car with about 100,000 on it last year in FL for $18. Still haven't cleaned it up yet an installed it. Toe adjusters came out easy as you please (I know mine are seized, but the alignment is still pretty good). It is a good idea to get the whole set up, refresh that, then swap as an assembly and you don't have to worry if the pivot bolts are seized in yours.
Originally posted by zedjr10 View PostThe bolts aren't rusted. Had them off about 8 months ago when installing rear shocks. I actually paid someone cause i couldn't get the bolt to line up right cause i was doing it in a parking lot at night and it was too difficult.
The Master Kit should come with everything you need including the bushings for the front and rear struts. I would still coat those bolts with anti-seize though.Henry R
Koni/Neuspeed
Legend FSM
Correction: Majestic's site actually shows part numbers and prices for all four bushings in the rear lower control arms.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
