Old 05-18-2018, 09:47 PM   #1
boulky12
boulky12 is cool... so far.
Gauge Cluster Lights issue
I've been trying to figure out this issue with my gauge cluster lights. It seems to me like a ground issue. I felt it would be easier to make a video showing you guys what's going on.
So please check it out if you have a minute : https://youtu.be/tsdr3FLWZMs
Thanks
boulky12 is offline   Reply With Quote
Old 05-21-2018, 01:19 PM   #2
boulky12
BUMP. Come on guys. Someone has to know something
Old 05-24-2018, 12:06 AM   #3
Mike1357
Mike1357 is cool... so far.
I took a look at the video and just had a few questions. Have you owned the car for a while and it just started doing this or did you purchase it that way? Do you know if that is the original cluster to the car? Do you by any chance have a spare cluster you could pop in there to see if the issue might be in the cluster? Has any recent work been done to the car that might have caused this?
Mike1357 is offline   Reply With Quote
Old 05-24-2018, 09:41 AM   #4
boulky12
Thank you for taking the time to look at the video and replying.
I've only owned the car about 2-3 months now. I purchased it this way.
I don't know if it's the original cluster to the car. Now that i think about it, a lot of the screws for the big trim piece were tampered with, so its probably not.
I actually do have a spare cluster that was in the trunk when I bought the car but never even tried plugging that one in to see what it does because I figured that one was bad, and they put the one in the car now, to replace that one.. But maybe I should give it a shot? It has more miles tho..
The issue is still the same from day one since I bought the car, so any of my recent work has not contributed to the issue.
Old 05-24-2018, 10:03 AM   #5
4GAccordH22
4GAccordH22 is cool... so far.
Send a message via ICQ to 4GAccordH22 Send a message via AIM to 4GAccordH22 Send a message via Yahoo to 4GAccordH22
You have a 90-91 cluster in a 93. Could be the issue.
The 92-93 cluster doesn't highlight 55MPH...
Originally Posted by Junior Smurff View Post
4GAccordH22 is offline   Reply With Quote
Old 05-24-2018, 03:39 PM   #6
boulky12
Really?? I'll definitely look into this.
And I'll check to see if that spare cluster has the 55 mph highlighted or not.
Thanks for replying!
Old 05-29-2018, 07:43 PM   #7
boulky12
So after rebuilding my suspension, new tires, and alignment all labor day weekend. I finally got around to trying the spare cluster that was in the trunk of the car when i bought it.
It is in fact a 92/93 cluster without the highlighted 55mph.
I plugged it in and ALL of the gauges don't work. Rpm's unresponsive, speedo unresponsive, fuel gauge reads Full when it's not, coolant unresponsive. I'm guessing this is why it was in the trunk and not in the car.
All the gauges did work with the 90/91 cluster so is it safe to say that the 92/93 cluster I have is bad and I should just get another from the junkyard?
The cluster lights did function like normal with the 92/93 so the problem is solved as far as the lights issue.
So what do yall think. Try another cluster? Anything I can look for on the new cluster that can ensure that the new gauges will work?
Old 05-30-2018, 09:58 AM   #8
4GAccordH22
I would try another cluster. Just make sure you can exchange it if it doesn't work. Most wrecking yards will let you exchange.
Old 05-30-2018, 11:59 AM   #9
boulky12
Got it. I'm gonna try another one, one of these days.
Thank you
Old 06-25-2018, 08:53 PM   #10
boulky12
I ended up getting a 93 cluster and everything is working perfectly now. Thanks guys
Old 06-25-2018, 11:12 PM   #11
4GAccordH22
Awesome! Glad it worked out. Always happy to help when I can, even though I sold my last Accord... :'(
