Old 06-15-2018, 02:36 PM   #1
Harriers Wake
Location: Albuquerque NM currently, Pasadena CA born and raised.
Harriers Wake is cool... so far.
Surging idle corrected by hard acceleration/Check engine light?
So something odd happened the other day. My '90 LX has a surging idle whenever the clutch is depressed. A fairly common issue that I've yet to remedy as I barely ever drive the car. I understand the need to do a vacuum leak search, clean or replace the IACV, etc. I drove the car for the first time in a couple months the other day and decided to get on her pretty hard because (let's face it) it's fun even if they're not exactly rocket ships stock. So I wind her up to almost redline in first and shift to 2nd. I catch a check engine light so I back off and depress the clutch. No surging idle. In fact it's dead set at 1500 rpm, not even a hint of a waver. It's like this all the way home. Park, kill it and fire her up again. No Check engine light and the dreaded surging idle has returned. Anybody know what's happening here?
Harriers Wake is offline   Reply With Quote
Old 06-15-2018, 04:14 PM   #2
fleetw00d
First thing would be to pull the code (it should still be in the ECM memory). Surging idle many times is the Fast Idle Thermo Valve (FITV): http://www.cb7tuner.com/vbb/showthread.php?t=206012
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Old 06-19-2018, 11:43 AM   #3
Harriers Wake
Thank you sir, If I take it to autozone will they be able to run the codes? Also, thanks for the link, I will check it out.
Old 06-21-2018, 02:06 PM   #4
G. Wiffington
Just use the blue service connector that is located under the dashboard on the passenger's side.
There are links on here about how to do this.
Put a paperclip in the connector to "jump" it. Turn the key to the on position.
Then you will see the Check Engine Light blink. A long blink indicates the first number of the code (10). The short, quick blink represents the second number of the code (1).
Here is the Thread: http://www.cb7tuner.com/vbb/showthread.php?t=21259
