Old 06-16-2018, 04:10 PM   #1
avcar
avcar is cool... so far.
wheel liner removal?
hi all i wish to remove the CB3 wheel liner off my dads accord. i can see most neat the wing/fender side are phillips screw however the other ones seem to be plastic welded on?
are there any tips to remove these to get the liner off in 1 piece?
Thanks
avcar is offline   Reply With Quote
Old 06-16-2018, 07:00 PM   #2
fleetw00d
Are you talking about the plastic front fender liners? All the plastic clips have the Phillips center screw (when you push/screw the screw in, it flares the little legs of the outer clip to keep it in the hole). Gently back the screw out most of the way, then you should be able to simply pull the whole clip out. The slots in some may be full of dirt and not look like screws, but from the factory they were all the same. You do have to take the mud flaps off first and they use metal screws.
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Old 06-17-2018, 01:17 AM   #3
avcar
Thanks thatís good to hear Iíll give it a go
Old 06-17-2018, 12:25 PM   #4
avcar
i managed to get the wing off without removing the whole liner, but can see it must have been the dirt thanks
Old 06-17-2018, 02:53 PM   #5
fleetw00d
What wiring were you going after?
