Old 06-29-2018, 06:22 PM   #1
funguy26
funguy26 is cool... so far.
Speedo, Odometer, trip, and cruse controll. Not working.
I try looking for some info on what is going on. I know I should have a yellow wire for power, an orange wire for signal, a black for ground. I replaced the VSS.
Now here it gets odd I got a Yellow/white giving 5v, A White/black doing nothing really good chance is the signal, and Green/white for ground. The car is a 92 EX with the 5-speed stick.
P.S. 2 people at a Honda dealer say is a Limited Edition version of the car. Really not sure about that.
funguy26 is offline   Reply With Quote
Old 06-29-2018, 07:30 PM   #2
deevergote
Don't call me dude.
Nothing limited about it. 92 EX with a manual is relatively common. If you have techs at the dealer with such detailed expertise, I’d find another dealer!
Anyway, if you can get your hands on a factory service manual, you should be able to get the info you need. Hondahookup.com might still be hosting digital copies. You can find them on amazon or eBay as well.
I don’t have any experience with vss wiring, so I’m not going to attempt a guess in case I mislead you.
Old 06-30-2018, 06:01 AM   #3
Ghostwhite
Ghostwhite is cool... so far.
Here is the page on VSS from the service manual.
Ghostwhite is offline   Reply With Quote
Old 06-30-2018, 10:30 AM   #4
fleetw00d
Just checking - when you replaced the VSS, did you put the pin that transfers rotation from the power steering portion of the VSS to the electrical portion?
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Old 06-30-2018, 09:51 PM   #5
funguy26
what? I check if the drive pin was in place for the sensor. I found there was no voltage from the yellow. wire it to the battery code 17 is gone. but the speedo, Odometer, trip or the cruise don't work.
Old 07-01-2018, 05:37 AM   #6
Ghostwhite
Here is the diagram for replacement. fleetwood is talking about the 'Joint Shaft' in this picture, if it is missing or broken your VSS will not read your speed.
If you measured from the center yellow pin/wire to the positive battery (+) terminal you should measure zero volts. You need to measure from the center yellow pin/wire to body ground. That means red/positive meter probe on the yellow wire and the black/ground meter probe to a clean body ground or the negative battery (-) terminal.
Old 07-01-2018, 04:03 PM   #7
funguy26
yeah the shaft is in place. do the gauge cluster give the 5v?
Old 07-02-2018, 01:35 AM   #8
Ghostwhite
Yes it appears so. What do you have when you measure from the orange wire/pin to ground?
Old 07-03-2018, 11:41 PM   #9
funguy26
Ok, I got it working! YAY! what I did was take the EGR plug and plug it in the VSS and take the VSS plug and plug it into the EGR valve.
Old 07-04-2018, 12:36 AM   #10
bobbycos
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
seen that happen before
bobbycos is offline   Reply With Quote
