hey fellow cb finatics i recently bought a 93 accord sedan i have swapped the engine in it with the same motor f22a1 the first startup everything in my guage cluster worked except the speedometer i swapped the speed sensor off a junkyard car and butt connected the clip part cause the mechanic ripped it off i also had to butt connect the egr valve aswell when i started it after that nothing works on the cluster except the battery light hazards and turn signals everything else in the cluster does not work i have swapped the gauge cluster itself the ecu and i have checked all fuses and relays everything is good but the cluster does not work if anybody can help me i would deeply appreciate it
faulty gauge cluster
