need help!! ac swap, is it possible?
    will the ac system from a 95 accord fit on a 91?
    the system is from a f22bx and i have a f22a6.
    like the compressor, lines, and condenser?
    anything is helpful
    Dont think it does, i sold my f22a6 condenser and guy told me it did not fit. Also i belive the newer accords have a screw on nozzle vs the cb clip on....not 100% sure but im pretty sure it doesnt fit
    Originally posted by Uncle Willey
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
      most likely its different. The compressor would fit if the fittings that plug into it are the same.
      You'd be better off sticking to CB a/c stuff
      And jaber what are you talking about clips and nozzles?
        thanks both of you guys. ill stick to the cb system then.
          um..not sure how to explain it, the piece where you recharge the systemVVV
          I believe the cb7 has a screw on and newer models have the clip/snap on.
            R12 systems are screw on fittings
            R134A systems are that snap on fitting
            In 1994 all cars moved to r134a which is why the fitting is that style.
              i also have a problem with my ac not sure where the leak is if its in the aluminum hose or rubber hose but do they make oem replacement parts for those or would i need to try and find a donor car and hope there is nothing wrong with that system?
                yea thats what i meant, if he were to change the condenser he would have to change the lines as well
                try majestic honda...they have oem parts a/c lines
                  the lines are bent specifically for the car, and i strongly doubt it will be feasible to fit 5th gen lines in the car. and i know for a fact the compressors are different.
                  if you have ABS, you will need a/c lines from an ABS CB7. otherwise any of the regular CB7 lines can be used.
                    bumpin up a old thread..... I have a f20a (japanese) RHD. My compressor died and i wanyed to know if the f20b or h22a compressors will bolt up to my engine.. thanks for any input....
