car just died
    why do you need key changed. all you need to change is the ignition switch with working unit.
    http://www.autozone.com/autozone/par...er=190369_0_0_
    A&P-IA
      did you tachometer twitch or flutter right before it died? if it did, then its your igniter unit crapping out.
      member's ride thread
      91 Accord SE 176k
        See post #9.
        Since he can keep the engine running by holding the ignition key FWD, the issue is more than likely with the ignition switch.
        A&P-IA
          Originally posted by 512_CB7 View Post
          Sorry bout the late post. I checked the fuses under the dash and hood everything is good on them. Tried the ignition thing and If I keep the key pushed all the way forward for the car to stay on and it stays running. But as soon as I let the key go it dies. So maybe the ignition switch? I plan on going to a junkyard tomorrow to look around and hope that's the problem. I called oreilly and autozone $286 and 3something at autozone.
          The ignition switch which I purchased from Autozone about 3 months ago was I believe somewhere between $60-$80. It came with a lifetime warranty. It sounds to me like you were pricing an entire ignition. You will not need a replacement key.
          '94 JDM H22A: 178whp 146wtq
          If you say double dutch rudder, i'm banning you...
            Well went to the jy and got one for $8 and no luck. So im taking it back and getting another I got a warranty with the 1st so no problems there but for $8 ain't no big deal as long as its all good by Monday!
              here's a vid of what I'm talking about
              91 Accord SE 176k
                Well late update. It wasnt what Losiracer2 was thinking but thanks for the video find always makes things easier when you see them(well for me anyways)
                And the issue with mine was the wiring on the ignition. I bought one from the junkyard switched them out and plugged them up and it worked!
                  Autozone was trying to sell me the whole thing thats why it was $300
                  http://www.autozone.com/autozone/par..._167189_0_1572
                  but either way $8 is better than $50
                  heres the one from the JY
                  And heres the JY one plugged up to the stock one to see if it works before completly taking out the stock one.
