Go Back   CB7Tuner Forums > Parts & Performance > Appearance
Old 02-16-2020, 11:02 PM   #341
CyborgGT
CB7tuner Member
CyborgGT seems to have made some friends!
Quote:
Originally Posted by JARHEAD293 View Post
the rear door are not interchangeable between sedans and wagons. the curve on the upper rear part of the doors are different.
Quote:
Originally Posted by blizzard335 View Post
Hence, the rear windows are not interchangeable
I can confirm that the sedan's rear windows DO in fact interchange with the wagon's. I just replaced a shattered passenger rear window on my '93 EX wagon with glass from a '92/'93 EX sedan. You may or may not need the matching regulator, I'm not sure. The alignment of my wagon's regulator could have just been off slightly, but I was having to force the window into position to line up both threaded holes at the bottom of the glass to where the bolts pass through the regulator. I didn't think about regulator alignment at the time and just swapped in the sedan regulator that I grabbed when I got the glass, and then it lined up without force.
__________________
MRT | Engine build | Daily RSX
Old 02-22-2020, 12:53 PM   #342
fleetw00d
Contributing Member
According to Majestic's site, the overall rear door frame is unique to the wagon, but the door skin is identical to the sedan; outer weatherstrip too. The rear regulators use the same part number as the sedan, but it calls out a unique part number for the glass.
__________________
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 384,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - you need it? you can have it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 02-23-2020, 03:21 PM   #343
PakaloloHonda
Contributing Member
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
Quote:
That is very interesting ... there is (if I'm not mistaken) a different curvature on the inside on the wagons where the door closes,
as opposed to the sedans .. and I believe the glass is w i d e r?
__________________
PakaloloHonda is offline   Reply With Quote
Old 02-23-2020, 04:21 PM   #344
CyborgGT
CB7tuner Member
Well the battery in mine is dead dead on top of having an internal short, so we'll see if there are problems once that's sorted and the car's actually driving - I got the seller to not put the date on the title, so I'm not registering it until after the engine swap. But on a battery charger, it rolled up and down just fine, if a bit slowly.
The part numbers for the glass sounds like a worthwhile reason to spend a day at the junkyard, though. At some point when I cross a wagon there, I'll have to pull glass from both cars and compare them. If they're different after all, the sedan glass may be riding the wagon's window tracks wrong and stressing my motor, so it'd be worth swapping out again.
__________________
Old 03-06-2020, 03:55 PM   #345
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
I just found out that the European wagons have shorter inner tail lamps with an integrated rear fog on the passenger side inner tail lamp.
vs
American (my wagon for reference. That's my friend GraniteCB7 in his 1991 SE)
__________________
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
HenRoc is offline   Reply With Quote
Old 03-06-2020, 07:22 PM   #346
Grumpys93
Contributing Member
Makes sense when you think about it. Since they use massive license plates. But I didn’t know that either.
__________________
~Nick~
Old 03-07-2020, 10:45 PM   #347
CyborgGT
CB7tuner Member
The 90-91 coupes and sedans, and I'm pretty sure the 92-93 coupes, did that as well. Personally, I'm glad for our shorter plates. I think the longer taillights make the car look wider, which helps the overall look when it's lowered.
And that fog is on the driver side. I thought I read once that when a car only has a fog light on one side, it's supposed to be on the driver's side.
__________________
Old 03-08-2020, 10:51 PM   #348
PakaloloHonda
Contributing Member
Quote:
OMG, I'd love to find that tail-gate and those tail lights ... I've seen the wag that has the coupe inners ... woww
Shipping would almsot surely kill the deal tho but yes! I didnt know that either!
__________________
Old 03-09-2020, 07:04 AM   #349
HenRoc
Black Thunder
You can see that square right in that passenger inner tail lamp.
__________________
Henry R
Koni/Neuspeed
Legend FSM
Old 03-09-2020, 07:40 PM   #350
Chrizzly92
CB7tuner Member
Chrizzly92 is cool... so far.
its an rhd car so the fog is on the driver side. Its a UK number plate and even though in most of Europe you drive on the right side, there are some countries where you drive on the left side of the roads - including the united kingdom.
regulations say that you need at least one fog light on the driver side of the car. you can have two on each side though.
Oh, and i dont know if its already mentioned somewhere in this thread - but the Wagon is called "Aerodeck" here in Europe.
Chrizzly92 is offline   Reply With Quote
Old 03-09-2020, 11:31 PM   #351
PakaloloHonda
Contributing Member
Quote:
__________________
Old 03-10-2020, 07:03 AM   #352
HenRoc
Black Thunder
Hmm I stand corrected. It just threw me off since I see that square inside that inner lamp.
__________________
Henry R
Koni/Neuspeed
Legend FSM
Old 03-17-2020, 11:08 PM   #353
fatboy1185
Big Cat
fatboy1185 seems to have made some friends! fatboy1185 seems to have made some friends!
Send a message via MSN to fatboy1185
How rare is the cargo cover/net?
fatboy1185 is offline   Reply With Quote
Old 03-19-2020, 04:13 PM   #354
PakaloloHonda
Contributing Member
Quote:
Not very, still see them on eBay from time to time, but a lil pricey ...
__________________
Old 03-22-2020, 02:56 AM   #355
fatboy1185
Big Cat
Weighed my wagon this morning. 1993 LX, no weight reduction, full tank of gas. 3,100lbs
Old 03-24-2020, 12:59 PM   #356
fatboy1185
Big Cat
Did the wagon in other countries come with two piece headlights? The nipple-less ones?
Old 03-24-2020, 06:01 PM   #357
CyborgGT
CB7tuner Member
^ I'm going to say yes. Someone correct me if I'm wrong in saying that the one-piece lights were only a JDM sedan option; even then, I've seen JDM sedans with two-piece lights, so I'm not fully sure on the specifics.
That bit of trivia was half of the inspiration behind my custom Euro R-style emblems
__________________
