Old 06-02-2011, 08:23 AM   #1
dertywhiteboy
dertywhiteboy is cool... so far.
motor swap Q?
i have a 92 accord with the f22a1 2.2l
i want to know if i can hook up a vtec motor to my stock tranny and use the stock ecu?
if not what all do i need?
dertywhiteboy is offline   Reply With Quote
Old 06-02-2011, 08:57 AM   #2
GhostAccord
Sure you can, you just won't have VTEC!
The Stock tranny will work but you'll need a VTEC ECU and a few other things. I'm sure there are one or two swap threads around here you could check out!
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 06-02-2011, 08:57 AM   #3
leroy457
leroy457 is cool... so far.
You can use the h2a5 with the h22 if i am not mistakenbut you would need a different ecu check out some MRT's.
leroy457 is offline   Reply With Quote
Old 06-02-2011, 06:54 PM   #4
deevergote
Don't call me dude.
If it's the F22B1 you are considering... the SOHC VTEC motor... don't waste your time. It offers very little in terms of additional horsepower, and really isn't worth the effort unless your F22A1 is on the way out. The only VTEC motors really worth considering are the H22A(1/4), F20B (DOHC), and H23A.
"what all you need" is laid out for you very clearly in the sticky threads at the top of the "Swaps" section. Just because you can't post there doesn't mean you can't read it.
