#1 |
![]() Past configurations:
![]() ![]() ![]() ![]() ![]() Current state: ![]() Mod list as of 3/16/19 ENGINE: [Bottom end] - Stock F22a6 from donor 92 EX - Balanceshaft belt removed [Top end] - Head: Intake and exhaust ports gasket matched - Delta cam 272 regrind - bisimoto valve springs - IAB delete - Bosch 315cc injectors w/resistor box delete - EGR delete [Management] - P28 w/ Hondata S300 [Engine bay] - Silicone filled front motor mount - P/S delete - A/C delete - Battery relocated to trunk - Radiator fans delete - Windshield wash relocated to cabin EXHAUST: - 4-2-1 header - Test pipe - 2.5" cat back - Cheapo racing muffler TRANSMISSION: - T2T4 transmission - Exedy stage 1 clutch - 10lb flywheel WHEELS / SUSPENSION: - Megan Racing Springs 280F/250R - KYB AGX adjustable shocks [Rallycross] - Front swaybar delete - OEM EX rear swaybar - 225/40R18 snow tires (finally someone making a cheap winter tire in this size!) [Autocross] - OEM front swaybar - ST rear swaybar - 225/40R18 BFG Sport Comp 2 BRAKES: - Powerstop Z26 kit up front - Stock drums in rear EXTERIOR: - Side trim delete - Poly side windows - Headlight delete - Vented hood - Swiss cheese bumper supports F&R INTERIOR: - Everything delete - Marine heater installed for defrost - Ebay race seat AUDIO/ELECTRONICS: - Delete, delete, delete FUTURE PLANS: - Roll cage - 5 point harness - Balance shafts delete - 70mm TB - New head build with more aggressive porting - Proper rally tires - BFG G-force R1 Auto-x tires - Fiery death ![]() Last edited by irelandmc; 03-17-2019 at 11:03 AM. |
#2 |
Front sway bar delete?
90 LX 4dr 5 spd 382,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450 92 EX coupe auto 196,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341 Sold 11/11/19 07 Element EX AWD 183,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623 INVENTORY REDUCTION! LOTS of CB7 parts - make me an offer http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right |
#3 |
^ To get that oversteer balance without buying an expensive aftermarket rear bar, I suppose? Instead of adding to the rear, take from the front?
![]() Not sure what the "fiery death" in the future plans is all about, either...
![]() Project CB9 AeroR start-up: ////////// Slowly but surely... and gunning for that NA list! |
#4 |
Yes, front SB delete to balance against the back. It would be nice to get something beefy in the back and then I could probably re-install the front. For now, the car balances pretty well, with just a slight tendency towards oversteer.
This is a good article https://grassrootsmotorsports.com/articles/lean-less/ Last edited by irelandmc; 02-07-2019 at 11:49 AM. |
Tags |
auto x , f22a6 , rally x |
Thread Tools | |
