Just want to know if its normal??? should i be worried or just get used to the new sound???
Why am i getting a whistle sound on my AEM SRi???
Originally posted by Fernando is god View PostI don't think there are any leaks how can i be sure??? It only makes the whistle noise while driving if i put it in neutral or park it doesn't happen?!?!?
Or carb cleaner/starting fluid.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
You said it is whistling while driving. How about idling and right after you turn your car off? My sri makes a whistle sound only after i turn off the car. Startled me at first but like mozzandherb said you get used to it.
That bend shouldn't cause a whistle unless the filter is not sitting flush with the tubing.
Originally posted by Fernando is godOKay no leaks but i have noticed a huge waste of gas. before the install i would go to and from work 2 weeks before filling up and i think i wasted a half a tank in one day!!! WTF?!?!?
