Oil light comes on randomly?
    The oil light comes on randomly in my 92 Accord automatic, i just changed the oil less than a month ago so I am at a loss. It tends to flicker or turn on dimly when I idle at a light. As soon as I hit the gas and start to move the light turns off. I have heard that the oil pressure switch might be bad?
    Could be: bad sensor, bad sensor connection, bad wire between sensor and ecu, clogged oil pick-up, or...... a failing oil pump. First and easiest step is to inspect the sensor connector, make sure its on securely and not broken. While there, look for oil coming from the sensor.
      Check your oil level.
      I once was turn pretty hard on a off ramp and my oil lamp light came on. I later checked my oil level and it was 2 quarts low
      1993 Accord LX Coupe 5spd
        Thanks Ender, ill get home and inspect the sensor and make sure its on securely. I've never had this problem before so its had me scratching my head.
          My oil level should be good, i just had and oil change. Even moments after the oil change the light began to flicker so hmm.
            And as suggested above, double check your oil level. But in all honesty, sounds like either a clogged pick-up or a failing pump. Start with the switch.
