Door locks
    Door locks
    I do not like how you have to lock your car on the outside with your key and not inside with the switch. Is there anything i can do or change to when i lock it with the switch it will lock the driver side door too?? Help is greatly appriciated, Thank You!
    Check out my MRT: http://www.cb7tuner.com/vbb/showthread.php?t=189190
    Hold the inside latch open on the driver's side as you lock the doors with the switch. Peace
      wow that easy! thank you very much!!
        If you decide to go keyless entry later on you can lock the doors with the remote and not have to worry bout holding the latch open. Peace
          i wanted to do that, but how much will it run me to get a good pair
            DEI makes a good cheap keyless entry system. I think DEI is a cheaper Viper system or something like that, don't qoute me. And there easy as shit to install. Hit me up if you decide to get one I got some diagrams for you. Peace
              On mine I can push the button on either driver or passenger side and all the doors lock. Or do you not have power locks?
