Ok so here is my problem. I was driving to work one morning and I noticed my gauges and clock had stopped working then later that day I realized my windows were no longer working. I am pretty sure its a short but I was wondering if anyone else has had this problem and how they fixed it. any help would be appreciated.
guages windows and clock not working
Not yet, people have been telling me it could most likely be a bad ground. I just haven't had any time to check it out and as far as the gauges go I am pretty sure there is a burnt spot on the back of the board, so I'm going to swap in 1 from my other car and see if that fixes the gauge problem. I will let you guys know.
THERE IS A GROUND UNDER THE DRIVERS SEAT!?!? I did not know that. I guess I will have to check it tomorrow. My car also wont start with the key anymore, but it will start if you jump the starter.Last edited by riotstarter1992; 01-06-2014, 09:43 PM.
I figured out most of it. It turns out the windows, rear window defroster, gauges and low setting on the wiper are all on one fuse that I missed when I was checking threw them. I still haven't fixed the dash lights yet but I think its the dimmer switch. As for the key, it is a bad relay that I just jumped or temporary. Thanks for all the help guys I am greatful for it.
