Old 06-16-2018, 02:14 PM   #1
Rat
Rat is cool... so far.
Bad Collant Temp Sensor and Rough Idle
I've been working on my 92 for a while now and have fixed the idle surge and corrected the timing. But my idle RPM will randomly drop about 100 RPM lower than normal idle. I checked for codes and found that my Collant Temp Sensor is faulty even though I replaced it two months ago. Could this Sensor be what is causing my suddden idle RPM drop?
Rat is offline   Reply With Quote
Old 06-16-2018, 02:50 PM   #2
fleetw00d
There are a number of things that affect idle speed: temperature, electrical load, PS load, AC on or off, etc. What idle speeds is it changing between? Under what conditions?
90 LX 4dr 5 spd 378,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Old 06-16-2018, 09:57 PM   #3
Rat
The idle rpm drops to about 450 to 550. My AC doesnt work so its never on. I checked my battery voltage when the rpm dropped and it was about 13.75. It only ever goes that low when it is in drive. When it is cold out it does it a lot more. Now that its getting warmer in my area it doesnt act up as much but still acts up from time to time.
Old 06-16-2018, 10:35 PM   #4
fleetw00d
The bottom end of the tach actually starts at 500 rpm. Auto or manual transmission? With the trans in neutral, the engine is supposed to idle at about 700 rpm. Have you attempted to set your base idle (find instructions in the DIY section)?
Old 06-16-2018, 10:41 PM   #5
Rat
I have not. I will look into that.
Old 06-27-2018, 02:12 PM   #6
Rat
So I checked the base idle and that improved it a bit. But I just got a new ecu from a lude and that seems to have mostly fixed it. Maybe it was my old ecu?
