i have a cb7 with coil overs its siting pretty low (you can see the pic if you check out my other post)but i have butterfly wheels on the front and last moth i put brand new tires on the front and now the inner thread is all gone but the inner part like u can see the mettle that's in the tire, the rest is still there....and its killing me plzz if there's a way you guys can help me plzz do so drop me a message cuzz i really don't know to much how to use this site lolxx so if there's any way... i can fix it or has any 1 done this or had this happened to them let me know... tell me a way to fix it plzz ill really be thank full of it...
need help butterfly wheels
Ok i my thoughts are that your running a negitive camber with a posable toe out so your tires are going like this /(tire leaning inn) \ (wheel steering wheel is strait the tire is pointing out wards) This type of problem is really bad it will kill tires very quickly. This pic will help you understand what im saying about toe.http://www.actiontireco.com/images/toeintoeout.jpg and this one is the camber http://www.actiontireco.com/images/camber.jpg
Originally posted by Monster2cb7 View PostOk i my thoughts are that your running a negitive camber with a posable toe out so your tires are going like this /(tire leaning inn) \ (wheel steering wheel is strait the tire is pointing out wards) This type of problem is really bad it will kill tires very quickly. This pic will help you understand what im saying about toe.http://www.actiontireco.com/images/toeintoeout.jpg and this one is the camber http://www.actiontireco.com/images/camber.jpg
OK now here come the ??
1. Is your car lowered?
2.look around too see does alinments in your local area seee how much they are?
3.Have you Checked your upper and lower ball joints?
4.Have you looked at buying a camber kit and or pellow ball mounts?
5.when did you get those rims?
6. Do you have a camber kit?
If not here is a couple complet kits
http://www.andysautosport.com/honda/...mber_kits/spc/
http://www.andysautosport.com/honda/...kits/progress/\
http://www.andysautosport.com/honda/...l_mounts/tein/
I dont know but i could call some of my buddies back home with civs to see if the camber kits are the same. Or what you could do if call your local import perfomance place there in cali and see because cali is the mecca for hondas so in the morning call some of you import shops. but it might take some jerry riging for a civ camber kit to work for our cars.
lol you will love the cb7 once you get used to its little qurks that they have alot of the guys on here have had many cb7 or have like 5 of them right now.
There are something about cb7s that you just like so much you will really fall in love with it. I do auto cross in mine and its my DD so yea its my baby.
