Go Back   CB7Tuner Forums > Site Features > DIYs > Suspension DIYs
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 02-06-2013, 07:15 PM   #61
8ball
CB7tuner Member
8ball seems to have made some friends! 8ball seems to have made some friends!
so you can u turn and parallel park using the palm of your hand?
8ball is offline   Reply With Quote
Old 02-15-2013, 01:59 PM   #62
GreenMadness
CB7tuner Member
GreenMadness is cool... so far.
Send a message via AIM to GreenMadness
parking is all based on setup, i run toe out with only -1.5 deg of camber plus some added castor and good tires and i nearly come out of my seat trying to take make a right at a stop sign.
__________________
Engines hate me... thats why they commit suicide
GreenMadness is offline   Reply With Quote
Old 01-29-2015, 04:11 PM   #63
Lucien
CB7tuner Member
Lucien is cool... so far.
Send a message via AIM to Lucien
RESURRECTION IN PROGRESS...
So has anyone effectively eliminated the excess wheel play that this mod introduces?
Lucien is offline   Reply With Quote
Old 05-26-2015, 12:38 PM   #64
esskater892
CB7tuner Member
esskater892 is cool... so far.
Alright I did this thing here but have not installed it yet. I left the spring and I guess piston in the rack and really only took out the valve body stuff. But I did grease everything like mad. Should I take the piston out? And as for thos plastic things I'm not sure I follow on that.
__________________
Accord SE
93se
Members Ride
esskater892 is offline   Reply With Quote
Old 07-01-2015, 01:01 PM   #65
Rilas
Gold Member
If you leave the following in the rack it will eliminate the excessive play left in the rack.
Here are the required parts to keep if you don't want excessive play in your steering wheel when converting to manual rack.
Valve not being removed. This valve has a slot in it which holds a pin on the bottom of the shaft with the gear on it. Here you can see the hole the pin sits in with the valve installed. I'm sorry for the shadow I took about 10 pictures and adjust lights but this is the best I got. Hopefully you can see what I'm trying to show here.
Valve installed in Valve Body with Pins and Spings 1 (In the picture it is installed upside down I apologize.)
Valve installed in Valve Body with Pins and Spings 2 (In the picture it is installed upside down I apologize.)
Pin on bottom of shaft matching up to the hole that is rests in. See how large the hole is in comparison to the pin? If you remove the valve that is pictured above that is how much play is left in the wheel. The pin has to move all the way across the hole and hit the far side before the wheels begin to turn. By leaving the valve in all play is removed.
Grease used for manual rack conversion
Manual Rack Completed 1
Manual Rack Completed 2
Old 07-02-2015, 02:53 PM   #66
Lucien
CB7tuner Member
Excellent! Thank you, sir!
Old 06-06-2016, 09:29 PM   #67
xkjnboix
CB7tuner Member
xkjnboix seems to have made some friends!
Send a message via AIM to xkjnboix
i know this thread is old but im doing this now.
im glad i read the update on reply #65
ive been reading about the different types of grease and for this application you would prefer something with moly.
personally i feel that any grease will work fine as long as its applied accurately
ill be buying new inner tie rods just for the lock washer as mine were a bitch to remove. i completely destroyed the original ones and the oem part costs almost as much as a cheapy replacement and all i need is the lock washer. ill just have spares until i need them
also what did you guys do about the VSS as it is lubricated by the PS fluid?
__________________
frostwhite225@gmail.com =VENMO
http://www.youtube.com/watch?v=NOB38zJu66o
[color="Magenta"]
xkjnboix is offline   Reply With Quote
Old 06-07-2016, 02:08 PM   #68
Rilas
Gold Member
For the power steering speed pump which the vss sits on top of, put a line on it and fill it. Spin the pssp while doing this to fill it with fluid. Once the hose and pssp are both full of fluid take the hose and fit it over the other fitting on the pssp and clamp it down. Now it has fluid in it and is self contained. You can also get a pssp from a 5th gen Accord and not have to worry about the fluid in it.
Old 10-25-2017, 11:04 PM   #69
Grumpys93
Contributing Member
THE SOLUTION TO ELIMINATING STEERING PLAY:
Here are the two washers:
Thickness of both washers:
Two washers on the valve side:
Two washers on the cover side:
I dropped it to the ground and sure enough no more play. Great job Will figuring this out.
__________________
~Nick~
Old 10-25-2017, 11:38 PM   #70
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
cp[mike] is very helpful cp[mike] is very helpful cp[mike] is very helpful
Great job, and thanks for the updated pictures!
__________________
cp[mike] is offline   Reply With Quote
Old 10-30-2017, 08:29 PM   #71
Mike1357
CB7tuner Member
Mike1357 is cool... so far.
That is exactly the information I needed. The slop is what kept me from doing this. Looking forward to doing the conversion now!
From the look of things, retain everything in the pictures and add a total of 4 washers, 2 on each side, and it will be good to go?
__________________
Mike1357 is offline   Reply With Quote
Old 10-30-2017, 09:28 PM   #72
Grumpys93
Contributing Member
You are correct mike.
__________________
~Nick~
Old 10-31-2017, 09:46 AM   #73
Bunta
CB7tuner Member
Bunta is cool... so far.
so the washers can be added and that is it or does one need to remove anything to make room for them?
Bunta is offline   Reply With Quote
Old 10-31-2017, 01:17 PM   #74
Grumpys93
Contributing Member
No need to remove anything. Just open it all up, grease it down, and add the 4 washers
__________________
~Nick~
Old 04-27-2019, 12:20 PM   #75
djALBINI
Gold Member
djALBINI is cool... so far.
block off plate solution??
check this youtube vid out... feedback???
https://youtu.be/sNNR1zANQ2g
djALBINI is offline   Reply With Quote
Old 04-28-2019, 08:47 AM   #76
Rilas
Gold Member
I have seen this done a Civic rack, and eventually plan on doing it to my rack. The above listed way requires no extra tools and material. Just throw a few washers in there and it tightens everything up the same. Granted you can save a few pounds on the car by adding a block off plate.
Secondly he should have added breather ports for the left and right side. Basically drilling holes where the ports are on the body into the block off plate to release the pressure that does build up in the rack.
__________________
Old 04-29-2019, 07:06 PM   #77
djALBINI
Gold Member
I believe that the removal of the blue ring and metal support behind it as seen in the video at 10:01 will not allow pressure buildup from steering... Perhaps this will work?
I just tried this and am planning on installing it as soon as I get my TL wheels back from powdercoating and installed. I will get back to you when this happens
Old 06-02-2019, 11:28 PM   #78
af_1132
CB7tuner Member
af_1132 is cool... so far.
Send a message via Skype™ to af_1132
I just did this conversion and was about to finish attaching the pinion to the steering arm, when I noticed that I forgot to put the large cylinder spring back in. I reinstalled the cylinder earlier based on the new info contained in this page, but the Spring slipped out of the black housing and I missed it! Do you guys think it will be okay to have the cylinder in there without the Spring, or do I need to pull it back out again and either remove the cylinder or add the spring?
__________________
*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:55.317
af_1132 is offline   Reply With Quote
Old 06-03-2019, 03:35 PM   #79
djALBINI
Gold Member
Manual rack installed and works great... smooth as butter! as done in previously posted youtube link. Just need four wheel alignment as I added various perf parts to front and rear suspension and should be good to go.
Old 06-15-2019, 12:52 PM   #80
af_1132
CB7tuner Member
Just wondering, do we actually need the rack tensioner at all? I understand using the cover bolt and nut to keep dirt out, but there is still quite a bit of tension in the rack at low speeds, and I am wondering about removing the spring and tensioner piece.
__________________
MRT
Selling on Ebay!
15.10 @ 90.42mph
