Go Back   CB7Tuner Forums > Site Features > DIYs > Engine DIYs
Old 12-22-2009, 03:36 AM   #1
Losiracer2
ENG: Master Cylinder Install and Bench Bleed VIDEO!
I found another useful piece of DIYtastic information on youtube. This time its for installing and properly bench bleeding a master cylinder prior to installing it on a car. It looks like it was done on an integra, but all early 90s hondas such as ours pretty much use the same process. I know this will help me when I have to do a master cyl. on my car in the future, so I thought I'd share it w/ you guys/gals. I HIGHLY recommend a moderator sticky this....this is a very useful vid.
member's ride thread
99' Lexus LS400 152k VVTi V8 gets up & goes...new DD
91 Accord SE 175k
97' Honda Odyssey 195k miles...$485 spare van for my parents
Old 12-22-2009, 04:12 AM   #2
accordztech
accordztech is cool... so far.
Send a message via AIM to accordztech
i personally would of done a FULL brake bleed in all 4 corners, your dirty already take the extra 39 minutes to get that old fluid out of the system that has taken alot of moisture and put some new stuff in it.
Retro!
Hater
accordztech is offline   Reply With Quote
Old 12-22-2009, 04:45 AM   #3
Losiracer2
yeah that would probably be the right way to do it. If you put a new MC in, might as well make sure that it has fresh fluid going through all 4 corners.
91 Accord SE 175k
Old 10-04-2011, 07:06 AM   #4
visualpoet
visualpoet seems to have made some friends! visualpoet seems to have made some friends!
Send a message via AIM to visualpoet Send a message via MSN to visualpoet Send a message via Yahoo to visualpoet
I ususally don't raise a thread this old, but:
GOOD LOOKING OUT!!! I was having brake fade at a stop, and they were needing the occasional extra pup rolling. This was wonderfully helpful. I was not looking forward to bleeding all four corners. Took me less than an hour, AND the breaks are better than they've ever been. I went with an inexpensive, brand new MC from O'Reilly's (came with the reservoir and cap with pigtails and plugins - I think Best Brakes was the brand) and DAMN is that thing responsive! Literally the best the brakes have been since I bought the car; I mean it's a "have to get used to how well it stops" difference!
Thank you sir! (and Eric the car guy)
visualpoet is offline   Reply With Quote
Old 08-07-2017, 08:27 PM   #5
fleetw00d
As mentioned in the video, I strongly suggest bench bleeding with the reservoir on. Get two short pieces of brake line with the appropriate fitting and enough rubber tubing to run the end back into the reservoir. With it mounted in a vise as shown, push the plunger, then pinch the hoses (similar to him using his fingers to block the ports), let the plunger out, then repeat as necessary until to you get two strong stream of fluid from the hoses into the reservoir.
You can leave your bleeding tube/hoses on the MC until you put it in the car, then you can quickly remove them one by one and install the brake line to minimze leakage. You can even do the bench bleeding with the MC in the car.
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 384,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - you need it? you can have it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
