Power Wire Installation Help ASAP
    i cant find a spot to run the power wire from my battery into the car..... where is there a good spot to run the wire threw from the engine bay????
    Passenger side, right above the ecu, there is a plug. Run it thru that
      man dude.... i done tried that as well man... lol no success like it was going threw were the wire harnest is but i couldn't find it inside.....
        you have to dig around for it..it would help if you remove the carpet
        Rush
        Originally posted by Darkcloud
        Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
        Originally posted by bmxicansd
        so you got a boombox, sunglasses and rosettta stone?
          ok.... im gonna try my best tomorrow morning hoping to get a positive outcome.... but i mean all i seen under the carpet was my big ass computer i think and just mad covers of things.... i even removed my glove compartment....
            It's above the computer against the firewall, you will see a rubber grommet.
              lol feed the wire from inside the car and grab it through the engine bay.
              YouTube Clicky!!
                haha just shove it thru the ac drip hole :P
                thats what i did cuz i got impatient in waiting to hook it up lol
                .My Ride.
                  The rubber grommet above the ecu might have to be cut a little bit to push the wire through but it'll go through it. Do like Sonik said and feed it through from the inside of the car into the engine bay.
                    its a pain ur first time but by clutch petal theres a spot after that u can re wire fast boy whole shaaaaa-banngi installed a deck amp and 2 12s in my boys cb in 30 mins i know the wiring ground spots ect.....
                    This thread is over a year old, you fucking retard.
                    i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
                      Running the power wire through on the driver side will take up another 3 feet of wire or so. I know it's not much but running it through the fire wall on the passenger side is the shortest route. You'd normally want to run the power wire through the firewall on the same side of the car that the battery is.
                        Did you decide to run your power wire on the passenger side of the car? I did on my install and it is definately easier than on the driver side. Worked great for me
                          this.
                          unless you have stock fogs there shouldnt be any wires, just a black rubber plug, maybe 6 inches above the ecu plate.
                          FA1
                          355
                            i did mine through passenger side and took my panels out on the side steps of the car and hid my wires underneath there andjust ran it thru my back seat..
