EXT: Custom LED parking lights?
    I got this idea from seeing various cars having a small "running light" in there headlights. So i said, "Why can't our accords have them... mmm." lol
    Tools Needed for this project:
    Drill
    13/64's Drill Bit
    Clear Silicone
    Wire Stripper's/Cutter
    Soldering Iron (Not really necessary)
    Electrical Tape
    16 Guage Wire
    Heat Wrap
    220-Ohm Resistors (Part# 271-1111 at Radio Shack, .99 cents for 5)
    Blue 5mm LED's (Part# 276-316 at Radio Shack. Something around 4$ for an led. Crazy! isn't it.)
    Ok, to start this off. Do this at your own risk... even though it really isn't a risk. Very very very simple DIY. Prolly the only thing dangerous is the soldering gun and thats opional really. I hooked the LED's up to me parking lights so they obviously only work when you either have just the parking lights on or the regular lights. I used 4 LED's (2 for each headlight.)
    Also I know many of you might not want blue as a color, So use this site http://www.kpsec.freeuk.com/components/led.htm . It helps you on how they work. Different colors may also use different resistors due to difference in volts, so make sure to remember that to save yourself some time and money.
    1. After you have all the tools, LED's, and resistors. You will have to attach the resistor to the LED. You need to attach the resistor to the positive prong with is idenified on an LED by the longer prong. I soldered them together and also placed a red heatwrap over it to make it easier for me to identify.
    2. When LED's have been prepped. You will need to drill a hole into your headlights. The 13/64's drillbit worked will with the LED's. I drilled 2 holes at an angle towards the chrome right above the highbeam. Drill slowly and blow a bit so you can remove the debris before it goes into the headlight.
    3. Next you will need to start the positive wiring. Take off your corner lights, and you will need to splice into the parking light (The one that doesn't blink... ). I used the wire stripper and just removed the red colored wire's casing. I didn't want to cut it and have to worry about it breaking apart. Attach a wire to the stripped piece, solder and/or tape it up, then run the wire to the holes you drilled. Connect the wire to the resistor side of the LED/'s. Tape it up.
    4. The negative side I did a little different. I ran it straight to the ground on the battery. Some might say why not right to the black wire on the running light? Well I tried and I'm not sure if I did somethign wrong, but I ended up blowing a fuze. I prolly touched the + & - together without realizing. So if ya want, try it and hopefully that works. Let me know if it does . If ya dont try, just run a wire to negative terminal on the battery and right to the LED/'s.
    5. After the wiring, place the LED/'s in the holes and silicone them in so no water comes in. Clean up, put the parking lights on, and enjoy the glow.
    Here's some pictures of the final project. Feel free the do something different and post us some pictures.
    She's winking at ya!
    Michalob's CB7
    I predict you get pulled over for that..
      not even a lil bit. its hard to notice it whenya have the headlights on. and just dont be dumb and drive around with just the parking lots on.
      Michalob's CB7
        Can you reload the pics or something, I'm not seeing them.
          grrr.... thats 2 places that wont host right. anyone know if im doing something wrong or who is good to host with?
          Michalob's CB7
            Have you tried photobucket? I've had good luck there.
              Posted with photo bucket. pictures please show this time!
              Michalob's CB7
                I like your idea and thought about doing this myself a while ago.
                I think I am going to go with orange. I think it will match the corners when just the parking lamps are on.
                Thanks for the info though
                  OMG.
                  I'm doing it. Putting it on a switch, but I'm totally doing it...maybe I'll just do it in my bumpers...but yes...I need that.
                    i can just switch it around and put in the LED's on the bumper lights right? and run it to a switch so i can have them on or off whenever? i heard it's hard to nearly impossible to get the lens off the bumper lights without a heat gun
                    Click Here for My Member's Page | Free money for searching the web. Needs PayPal account
                      Why bother...just drill them. I drilled them for my strobe lights, and they never leaked.
                        Make sure when you buy the LED that the "mcd" (I believe that's what it's called?) is pretty high. The higher the brighter. I believe the ones from radio shack are over 1,000mcd.
                          drill them where? i dont understand what you meant
                            yeah just drill the bumper ligths if your gonna do them. theres no big reason why ya acually have to get a heat gun. just use a 13/64's drill bit and insert the led. then silcone.
                            and for the mcd. yes keep an eye out for that number. the higher the brighter which is great in our cases. mine led's were something like 1400, i cant remember of the top of my head.
                            Michalob's CB7
                              awesome, yeah I wouldnt use blue, prlly amber to match the corners
                              *on the lookout for an h22 swapped 5 spd accord*
                              now for my P.O.S winter car/daily
                              1992 4dr escort lx hatch
                              NO MUFFLER-wrx sti tip(got fo free)
                              5 spd
